Tue, Dec 3, 10:30 AM CST
DAZ|Studio F.A.Q (Last Updated: 2024 Dec 02 9:02 pm)
Subject: Shiny and /or Sweaty Skin
arrow1 ( ) posted Wed, 01 March 2017 at 10:06 PM · edited Tue, 03 December 2024 at 10:16 AM
Can anyone help me with settings in DAZ Studio 4.9 for Shiny,Sweaty skin? Normally I just purchase textures/mats but I would like to experiment for myself.Also wet skin! Cheers
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses.  Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
Jack238 ( ) posted Thu, 02 March 2017 at 7:10 PM
Hi are you using IRAY or 3DL to render with?
You can play with the glossy settings in both. In IRAY, you can increase the weight of the top coat and add gloss to the top coat and also lower the glossy roughness. A lot depends on the lighting too.
I think it helps to play with the parameters as it is a great way to learn what they do and get more comfortable with them.
With IRAY you can change the drawing mode of the viewport to IRAY and it will show your changes interactively. You can do similarly with 3Delight in the aux viewport. I found both to be very helpful when experimenting with textures and their shader parameters
arrow1 ( ) posted Thu, 02 March 2017 at 8:07 PM
Many thanks for your reply.I am mainly a Poser user but I am trying to learn and experiment with DAZ Studio.I guess I need to play with both IRAY and 3DL! Cheers
flibbits ( ) posted Fri, 03 March 2017 at 6:24 PM
There's a wet skin for Genesis 3 Male and Female.
arrow1 ( ) posted Tue, 11 April 2017 at 3:57 AM
How do I get the viewport for IRAY to show? Also Where do I find the top coat parameter? I am still finding my way around DAZ Studio! Cheers
RHaseltine ( ) posted Tue, 11 April 2017 at 9:00 AM
Viewport modes are set with the icon (usually a sphere) to the left of the camera/view picker at top-right of the viewport. You can also use ctrl(Win)/cmd(Mac) plus a number key - 0 for nVidia Iray preview, 9 for texture Shaded.
To see the TopCoat parameters you will need to have the Iray Uber Base shader applied - imported geometry and Poser content will use the Daz Default Shader (3Delight) when loaded. The preset for applying the shader to selected surfaces on selected objects is in the Presets tab of the Surfaces pane under Shaders>Iray.
arrow1 ( ) posted Tue, 11 April 2017 at 5:39 PM
Many! Many! thanks for your assistance! Cheers
arrow1 ( ) posted Tue, 11 April 2017 at 10:51 PM
I am dammed if I can find the top coat or Viewport.I have tried everything mentioned but for me it does not work.Any chance of a screen cap? Cheers
arrow1 ( ) posted Tue, 11 April 2017 at 11:07 PM
All is OK. I found the settings! Having trouble making a shiny and sweaty skin! Any suggestions for settings? Cheers
Kokor ( ) posted Tue, 18 April 2017 at 12:56 PM
arrow1 posted at 10:52AM Tue, 18 April 2017 - #4302274
I cheat and use N.G.S. Anagenessis - II. I think it really helps skin materials in most cases. But to make the skin glossy/wet/oily I go to the surfaces tab, select the skin, then in the Anagenessis option I select Lip Gloss. Instructions say NOT to select any surfaces, but that is only because it will apply the effect to only that one surface - in this case that is what you want. Sorry if you don't have that product. But I would recommend you get it. I use it on nearly every character now.
