Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 16 10:02 pm)
Has there been any improvement to the sketch modes? Can Poser 11 produce full-on comic renders? I saw something in the advertising that showed it the new features to be as good as say, PWSketch, which I think is very good.
Sorry to ask all these questions but as a comic producer, I'm more interested in those features than anything else right now.
This is a Superfly toon shader, alone and with the lines (needs to be combined in Photoshop or so,)
A ship in port is safe;
but that is not what ships are built for.
-"Amazing
Grace" Hopper
Avatar image of me done by Chidori.
This is a comparison between the NPR shader from the Mariko Project (which I used in my previous image) and a Shader published by Infinity10 on RDNA, he calls it a modified Sanne shader. Please take note, both shaders are very light dependent, the shader on the right can look more flat if a different light set is used.
But for a flat shader which even generates it's own lines, the second shader looks really good to me.
-"Amazing
Grace" Hopper
Can I ask, why SuperFly is generating interest in toons? FireFly is better at non-photoreal rendering and capable of more effects than SuperFly, because SuperFly's BRDF set is mostly devoted realism, whereas in FireFly I can make a much broader set of shaders.
In FireFly you can make things you cannot do in SuperFly. For example, the colors reverse in shadows like this: (image by Vestmann)
See more about FireFly toon shading in this thread:
I know that, and I know how to get NPR images out of FireFly for quite a long while. It's just toying around.
The image above is rendered in FireFly.
-"Amazing
Grace" Hopper
that aiko one looks very nice HartyBart!!!
I aim to update it about once a month. Oh, and it's free!
can you do one in a scene with some shadows?
Happy to find some example of the comic rendering :)
I was just wondering if this feature is the same in Poser 11 as it is in Poser 11 Pro version ?
I was only really interested in the comic rendering so didn't want to blow a lot of money on Pro if I don't need to.
Also does it render quicker than a photo-realistic render ?
Many thanks !
Yes, it renders quicker.
I do have Pro, so I cannot check but looking at the comparison matrix you should be able to work with the non-Pro version.
-"Amazing
Grace" Hopper
Boni posted at 1:35PM Wed, 17 February 2016 - #4244777
funny. i used to create this imaging technique back in my photography days using 35mm film sandwiched with 35 mm slides or by projection onto 8 x 10 lith film in color darkroom. it was fun and expensive! good to see it is possible in poser. wish i could figure out how to do the same in photoshop for my older photos.
Here you go:
I hope these help. Let us know and share ... we'd like to know how this works for you.
Boni
DragonWhy asked: is "this feature the same in Poser 11 as it is in Poser 11 Pro version?"
Yes, Poser 11 Standard and Poser 11 Pro both have the Comic Book mode.
If you also render out a sketch layer of a suitable type (you may need to experiment for a while, on that) and the same size as your toon render, then in Photoshop you can use a big soft eraser to remove most of that sketch layer, just leaving shading that looks sort-of like hatching (see picture, below). Of course you have to run an Action to knock out all the white first, leaving just the sketch lines laid over your toon lines and colour flats layers.
That looks great!
Has anyone played with the new comics and painterly sketch styles. Curious how they are on the new system. What all styles does it offer now?
