Sun, Jan 5, 9:48 AM CST
DAZ|Studio F.A.Q (Last Updated: 2025 Jan 02 6:48 pm)
Subject: Genesis and IRAY
arrow1 ( ) posted Sat, 29 April 2017 at 5:44 PM · edited Fri, 03 January 2025 at 12:28 PM
Do not know if this has been asked before but Can Genesis and Genesis 2 textures be converted to IRAY? I want to use a variety of figures and render in IRAY. Cheers
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses.  Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
RHaseltine ( ) posted Sun, 30 April 2017 at 8:52 AM
It isn't the textures that need converting but the materials - though granted, if the current materials are very "old school" you may have trouble getting control of things like SSS/scattering. Anagenesis 2 at Daz works with a limited number of maps, so may be worth investigating, or you can just apply the Uber Iray Base shader which will leave all maps (using standard property names) in place while applying the Iray shader for further adjustment; in some cases it may also work to apply a regular Iray skin materials preset but hold down the ctrl key (cmd on a Mac) while doing so and in the dialogue that opens choose the Ignore option for Maps (this will skip texture settings, leaving the existing maps in situ, while applying the numeric values from the preset).
Jack238 ( ) posted Sun, 30 April 2017 at 9:17 AM
I have used the Uber Iray Base Shader and it does quite a good good.
Also at Daz, v3digitimes has converters for V4, Genesis, and Genesis 2. I have used them and I like that they provide quite a number of options in scripts with documentation.
Jack238
bhoins ( ) posted Sat, 06 May 2017 at 10:59 AM
There is nothing preventing you from using Genesis or Victoria 4, or even Victoria 2 in Iray. For best results though you are going to want to adjust the shaders, since Shaders are render engine specific. The converter built in (which performs the exact same function as applying the Iray Uber shader) is fairly good, if you are starting with a 3Delight skin shader, but they still usually can use some tweaking.
