Mon, Dec 23, 6:37 AM CST
DAZ|Studio F.A.Q (Last Updated: 2024 Dec 19 7:58 pm)
Subject: is there a restore default option in Daz 4.9?
angreif ( ) posted Thu, 08 June 2017 at 1:33 PM ยท edited Mon, 23 December 2024 at 2:18 AM
If so where and will it wipe out my loaded content. If I reload the same Daz 4.9 will that load on top of the existing version and leave content alone.
Thanks KEVIN
RHaseltine ( ) posted Thu, 08 June 2017 at 3:51 PM
No, not as such. is it the content or the database (Smart Content, Categories, Products) that is the issue?
angreif ( ) posted Thu, 08 June 2017 at 7:21 PM
Delicate issue. Freestuff. Non smart content. Deleted it once inside daz then reloaded and hunted down following the tree and deleted. While it deletes there is still part of it in the viewport. Big rectangle in the middle 1/3 of the viewport. Product functions after help from maker except standard starting focus range is hosed and results in the render being different from the viewport. Very frustrating. KEVIN
RHaseltine ( ) posted Fri, 09 June 2017 at 3:05 PM
If something is auto-loading it should be listed in Edit>Preferences>Start or Edit>Preferences>Scene (load on launch and load on File>New respectively). If you have items appearing in your viewport with nothing set to load then the issue is something else.
angreif ( ) posted Fri, 09 June 2017 at 4:50 PM
Thanks. Will try to check those places.
angreif ( ) posted Fri, 09 June 2017 at 7:53 PM
Both of the edit prefs found nothing. So where can we go from here?
angreif ( ) posted Fri, 09 June 2017 at 10:20 PM
Found something06-17Save6 useful. In the upper right of the viewport there is a dropdown and by shutting off "Show aspect frame and Show thirds guide" I get rid of the rectangle and the grid inside the rectangle. Now only problem remaining is the position of the G3 to viewport. Thinking this could be the default camera. What XYZ should the default camera be at load?
RHaseltine ( ) posted Sat, 10 June 2017 at 3:33 PM
Ah that sounds as if you had a background set in the Environment pane - if it was a solid colour that would have made a rectangle (though it should not have shown up unless you loaded a sceen with that set up - you can't, in 4.9, 4.8, and possibly 4.7, set the Environment persistently between sessions).
I suspect that the offset is not that the camera is misplaced but that the render aspect ration (as shown by the frame) is wide compared to its height - render size does persist between sessions, it can be set in the General group of Render Settings>Editor tab (you will need to turn Constrain Aspect ratio off first).
angreif ( ) posted Sun, 11 June 2017 at 7:52 AM
Went and looked about this morning. Without doing anything the viewport had returned to normal position. Still turned Constrain Aspect Ratio off. Seems to be back where it should be. Thank you Richard! You are a Daz Scholar of the highest Degree. KEVIN
buffalosoldier ( ) posted Sat, 01 July 2017 at 5:39 PM
i have one that I do not understand I loaded 4.9 and some how do not have any v4 body morph all I want to do is give her a shape as in the beginning does anyone know how to get it back thank you for your time
RHaseltine ( ) posted Sun, 02 July 2017 at 9:39 AM
And the morphs were working before? Check that the folder to which Victoria 4 is installed (the folder that contains the Runtime folder) is still listed as a Poser format content directory.
