Mon, Feb 3, 4:53 PM CST
Subject: Poser 11 Pro serial does not work
drifterlee ( ) posted Fri, 14 July 2017 at 2:11 PM · edited Mon, 03 February 2025 at 4:52 PM
Hi: I had to reformat my hard drive (Windows 10 64bit home) and reinstall everything. Poser Pro 11 says the serial that is on the install disk is wrong. I have checked it over and over. Does not make any sense to me. Anyone else have this problem? It is an upgrade and the old Poser 4 serial is correct also. Thanks, Sherrie
Boni ( ) posted Fri, 14 July 2017 at 2:40 PM
Here is my suggestion. IF you have a physical copy of PP11, Photocopy the document with the serial number on it. IF it's a download show the digital documentation with the sercial number. Attach this information to an incident report to SM. The procedure should be with your readme files or your manual. Let us know how this goes. Give them a little time as they've just had a change in staff recently.
Boni
kimreb55th ( ) posted Fri, 14 July 2017 at 11:54 PM
I don’t think you can upgrade from Poser 4 to 11. Depending on which version of the upgrade you purchased, you need to have from Poser 6 or Poser Pro 2010 installed for it to work.
ironsoul ( ) posted Sat, 15 July 2017 at 12:14 AM
Another thought is if the upgrade was from standard to pro the license checker might be looking for a valid standard version licence.
ratscloset ( ) posted Thu, 27 July 2017 at 12:14 AM
If you have an Upgrade Product, you need to use the Key used to purchase at the Upgrade Price.
ratscloset
aka John
EClark1849 ( ) posted Thu, 27 July 2017 at 5:50 AM
ratscloset posted at 5:49AM Thu, 27 July 2017 - #4310814
Wow, haven't seen that avatar in years, John. Didn't it use to wave?
ratscloset ( ) posted Thu, 27 July 2017 at 10:30 AM
Yes... it use to wave... I think the support for Animated GIFs is gone.
ratscloset
aka John
