Forum Moderators: nerd Forum Coordinators: Anim8dtoon
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2025 Feb 23 8:32 pm)
The FF hair node doesn't work in SF. And the SF hairbsdf shouldn't go into the transparency color. Try this shader for your SF, changing the colors to match what you want. And a traditional hair shader for FF.
It would be useful to have a FF to SF shader converter. This should be possible by having shader presets like "skin", "metal", "rocks", liquids or "glass" ect. So it should work like the Reality plug-in converts Poser shaders for the Lux renderer, this converter converts to Superfly. Somebody should make a script.
If you have Snarly's EZskin3, Bopperthijs created a plug in that not only enhances skin, but other materials too all to work with cycles.
This is the best so far. I hope this helps.
Cheers
Boni
One render has hair the other Does not any thoughts?Fire Fly First /second Super Fly![Fire Fly.jpeg]
