Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 19 2:39 pm)
Attached Link: http://www.3dmenagerie.com/index-goo.htm
heyas; not bad, there! :) if you poke through the tutorials section, you should find some tutorials about combining two figures together. as long as your blends are not on any body part seams, this should work well for you. it doesnt look like you'll have that problem, as i can see the horse foreleg bit blending in with the raptor thigh bit, there. you should parent all the raptors (i'm guessing there's 3) to the horse body, and then select the horse body and save to the figure library. this should save everybody all together and let you reload it whenever you need this character. the only real problem i forsee is the two front legs. you might have to go with one raptor each for those legs, and parent each one to the horse's forelegs. that will make it rotate properly. once you have the whole conglomeration in a cr2, you can go about editing it to cut out the unneeded bits. (ie: all the invisible parts!) you can check out the gryphon version 4 at my goodie page, created by jelisa and myself, to see how two eagles were blended with the p4 lion to create the gryphon. it isn't as complicated as this setup you've got, but its the same idea. (even if you dont have the eagle, you can look in the cr2).This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
