Sun, Jan 5, 8:11 AM CST
DAZ|Studio F.A.Q (Last Updated: 2025 Jan 02 6:48 pm)
Subject: about rotate
atpo ( ) posted Sun, 20 August 2017 at 7:17 PM · edited Fri, 03 January 2025 at 9:51 AM
RHaseltine ( ) posted Mon, 21 August 2017 at 9:53 AM
Which preset are you using in the import options? What was the model made in, if you know?
Jack238 ( ) posted Mon, 21 August 2017 at 10:27 AM
I think the question is can you change the center point of the rotate function and if so, how?
RHaseltine ( ) posted Mon, 21 August 2017 at 4:16 PM
Ah, sorry. You can use the Joint Editor tool to move the centre point (the green crosshairs)
atpo ( ) posted Mon, 21 August 2017 at 8:41 PM
Thanks. Model was made by pixologic sculptris alpha6. And x,x,z that how to be changed correctly in 'import parameter panel '? Because it always reverse.
RHaseltine ( ) posted Tue, 22 August 2017 at 3:49 PM
Try using the preset for 3D Studio Max, which also uses the opposite axis system from DS - if that gives the right orientation then you can adjust the scale, if needed, and save a new preset by clicking the button next to the scale box.
atpo ( ) posted Wed, 23 August 2017 at 7:16 PM
Thanks cat.
