Sat, Feb 1, 4:38 AM CST
DAZ|Studio F.A.Q (Last Updated: 2025 Jan 31 8:48 pm)
Subject: studio 4.10 rendering
goofygrape ( ) posted Sun, 29 October 2017 at 7:01 PM · edited Fri, 31 January 2025 at 10:31 AM
4.10 is installed and run's. a lot of new stuff the way it works ect. when wanting to render a figure or scene a popup come's up and say's no render engine. Iray is there,figured the same as studio 4.9,What gives am I missing something ? win 7 pro operating system.
Razor42 ( ) posted Sun, 29 October 2017 at 7:47 PM · edited Sun, 29 October 2017 at 7:47 PM
In the past I have seen a number of issues that can cause this.
Did you use DIM to install?
Is DS installed on an external drive?
Are you using a default installation path or a custom one?
Sometimes certain file paths may cause issues such as special characters used in some languages.
goofygrape ( ) posted Sun, 29 October 2017 at 10:47 PM
Razor42 I used a zip from Daz3d. C drive program files Dim downloaded to my download file so I used the zip I got from my file area at Daz3d.Do you think I should use dim? should I start over? Thank's for your idea's
RHaseltine ( ) posted Mon, 30 October 2017 at 10:27 AM
What GPU? The minimum requirement has changed with the new vrsion of Iray included so if's an old card (4x0 I think) it may no longer be supported (though CPU should still work).
goofygrape ( ) posted Tue, 31 October 2017 at 5:23 PM
RHaseltine; thank's for response,card is asus Nvida 750ti 2gb,Cpu is AMD 955 black running at3.5 gb,.By the way the public beta 4.10 renders fine .The beta is installed by DIM into c: program files,The studio 4.10 is in users public,public documents ,MY DAZ 3D Library ,. Should I untick the gpu mark in advanced Iray area?
RHaseltine ( ) posted Wed, 01 November 2017 at 10:17 AM
A 750Ti should certainly be working, that's what I have (though not with the latest drivers, by any means). You shouldn't have an application in the documents folder, though whether that's the root of your issue I can't guess.
goofygrape ( ) posted Wed, 01 November 2017 at 2:43 PM
RHaseltine thank you
goofygrape ( ) posted Wed, 01 November 2017 at 3:17 PM
Not to bother anybody further, but can I just move the studio file from users to drive c:?
RHaseltine ( ) posted Wed, 01 November 2017 at 4:54 PM
I'd recommend uninstalling and reinstalling - even if moving iss till safe, and I haven't tried since DS2, if you are trying to trouble-shoot it's best to do things by the letter.
goofygrape ( ) posted Wed, 01 November 2017 at 6:05 PM
ok will do.
goofygrape ( ) posted Thu, 02 November 2017 at 1:25 AM
Ok found the problem studio 4.10 as installed doe's not recognize the video card,so installed and reinstalled to drive D: program files Daz3d . everything is shipshape now . Thank's for the help that made me think. good day 😃
