Fri, Jan 31, 11:25 AM CST
DAZ|Studio F.A.Q (Last Updated: 2025 Jan 30 6:38 pm)
Subject: I Need Help!!!
arrow1 ( ) posted Fri, 06 April 2018 at 8:48 PM · edited Fri, 31 January 2025 at 11:25 AM
Does anyone recognize this figure? Somehow I have installed this figure and it has overridden all my Genesis 2 figures! I have not used or installed any Genesis 2 figures recently.I have checked what I have installed in the recent passed but I cannot find this figure.Any help would be appreciated. CheersGenesis 2.jpg
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses.  Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
ice74 ( ) posted Fri, 06 April 2018 at 10:18 PM
At first I thought it was the Aiko 6 model, I just checked all my possible characters based off Genesis 2, I couldn't match any up. What you could try, is go into your Install Manager and un install the Genesis 2 female starter essentials. Reinstall them. I lost some of my content a few weeks ago, so I re installed the products and somehow it reset everything within the program.
arrow1 ( ) posted Sat, 07 April 2018 at 1:20 AM
I have already uninstalled and reinstalled genesis 2 Starter essentials via Install Manager and the problem still arises. I am at a loss! Many thanks for your reply.Cheers
Jules53757 ( ) posted Sat, 07 April 2018 at 2:53 AM
It looks like a character that has set his morph to 100%. In this case the morph is set whenever you load G2F. Check the morphs and then either you delete this from the data folder or you edit the respective data file.
Ulli
hborre ( ) posted Sat, 07 April 2018 at 8:36 AM
I have this happening with the Aiko morphs loading whenever I load G2F. Annoying, but easily fixable. You might be having a combination of different characters activating at the same time.
RHaseltine ( ) posted Sat, 07 April 2018 at 9:22 AM
The non-zero shapes should be listed in Currently Used in the Editor tab of the Parameters pane, with the figure selected.
arrow1 ( ) posted Sat, 07 April 2018 at 7:24 PM
RHaseltine, Could you expand a bit more for me on what you mean? CheersG2 Paremeters.jpg
Razor42 ( ) posted Sat, 07 April 2018 at 9:10 PM
You need to select Currently Used. This will list any morph that is dialled in and should help you locate the problem morphs on the figure. Untitled-1.jpg
FlagonsWorkshop ( ) posted Mon, 09 April 2018 at 1:33 PM
I usually knock them out on the shapes tab. I have something that keeps setting Teen Julie to 100% on Genesis 3 female, haven't gotten around to finding out what's doing it, but you'll find the character there. Until you do locate the culprit, you'll need to lock that morph to 0% after you fix the figure or some poses will put that morph right back in. It's likely cause by a new character you purchased where the morphs are in the wrong directory. There are others here who can get more specific on that for you than I can.
arrow1 ( ) posted Tue, 10 April 2018 at 1:24 AM
I found the culprit! But I cannot find the DATA files It is call called Stacia both head and body. Cheers.Stacy Head 2.jpg
RHaseltine ( ) posted Tue, 10 April 2018 at 9:23 AM
Try clicking the gear icon on the Stacia slider and selecting Parameter Settings, setting the Default Value to 0, and finally using File>Save As>Support Assets>Morph Asset to resave only the Stacia morph, with its original values.
FlagonsWorkshop ( ) posted Tue, 10 April 2018 at 1:18 PM
Hmmm, thanks Richard, I'll have to try that with my problem. It wasn't Teen Julie itself that did that, I think it was one of the shaping packs I bought here.
arrow1 ( ) posted Tue, 10 April 2018 at 3:51 PM
Many thanks.I will try your suggestion. Cheers
arrow1 ( ) posted Tue, 10 April 2018 at 11:14 PM
I tried saving as support assets.It did not work! When I clicked on Genesis 2 Female the same Stacia Character came up! Cheers
RHaseltine ( ) posted Wed, 11 April 2018 at 9:54 AM
OK, in that case you need to find and remove the .dsf file for Stacia in /Data/Daz 3D/Genesis 2/Female/Morphs.
arrow1 ( ) posted Wed, 11 April 2018 at 3:36 PM
That is the problem. I cannot find the Stacia Morph anywhere in the Data file! Cheers
Razor42 ( ) posted Wed, 11 April 2018 at 7:33 PM
Have a look here if this is the same character. http://docs.daz3d.com/doku.php/public/read_me/index/20783/file_list
RHaseltine ( ) posted Thu, 12 April 2018 at 9:24 AM
If that is the product then uninstall it, and if your figure loads check to see if it's been updated and bug report it if not.
Bejaymac ( ) posted Fri, 13 April 2018 at 3:51 AM
Richard, no point in bug reporting this, take a look at the feet in both images, they are posed, if that is how G2F is loading then several files have either been overwritten since they were installed, or the OP has installed something that has changed/replaced them.
