Fri, Dec 13, 4:41 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 12 6:08 pm)
Subject: Animating one texture material image to another image possible?
putrdude ( ) posted Wed, 06 June 2018 at 6:05 PM · edited Fri, 13 December 2024 at 4:40 AM
I'm playing with animating a chameleon like monster that changes from moon sand texture to his original monster texture. Is there a way to do this in the material room. Using poser 11, Firefly render. It's not a super must have as I think I can probably just redo the same animation with each skin and then blend in photoshop animation, but I thought i'd ask if there was a way.
Thanks!
seachnasaigh ( ) posted Wed, 06 June 2018 at 10:52 PM
You can use the frame number node and a few math nodes to segue from texture 1 to texture 2.
I've got a scene using Rokket's Blaze superhero character somewhere; I'll make a material screenshot.
seachnasaigh ( ) posted Wed, 06 June 2018 at 11:49 PM
ironsoul ( ) posted Thu, 07 June 2018 at 12:58 AM · edited Thu, 07 June 2018 at 12:59 AM
Clicking on the key symbol next to a parameter makes it appear in the animation palette which could be used to control the blending node manually if you wanted a non linear progression.
putrdude ( ) posted Thu, 07 June 2018 at 1:50 PM
Thanks! How do you know this stuff!!!????!!!!
JAFO ( ) posted Sun, 10 June 2018 at 7:29 PM · edited Sun, 10 June 2018 at 7:39 PM
But then again you could simply animate your texture... Maybe create a series of various textures and use a morph program to create an avi of the transitions from one to another... Here the background is the body texture of the frog.
Y'all have a great day.
putrdude ( ) posted Mon, 11 June 2018 at 4:56 PM
haha, that's great. I don't know if I'll actually do it. Animation takes so long and I'm wearing a lot of hats these days. Even if I resolve the problem of the changing texture, the same scene involves debris like rocks and sand falling off the creature hiding in the ground. I "think" i have a way of doing that, but for a 60 second book promo this may be overkill. Many thanks.
