Tue, Jan 21, 1:35 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 11:41 am)
Subject: weight mapping issue
AnyMatter ( ) posted Sun, 15 July 2018 at 7:08 PM · edited Fri, 17 January 2025 at 3:52 AM
hi members, please look at the image below, the object is a smooth 3dmodel at 1st, once skeleton applied and weight mapped, unwanted dark spots show up around the model... any idea how to fix it?
rokket ( ) posted Sun, 15 July 2018 at 10:33 PM
Do they render like that? If not, then don't worry about fixing it
AnyMatter ( ) posted Sun, 15 July 2018 at 11:17 PM
greetz rokket,
same thing happened ,rendered in firefly ...poser 10
rokket ( ) posted Mon, 16 July 2018 at 8:07 AM
Poser 10? Try to add subdivision and see what happens. If it's the same, I am at a loss...
AnyMatter ( ) posted Mon, 16 July 2018 at 9:19 AM
my goat... worked like a charm ,need no subdivision though, just change skinning method from traditional to unimesh. rokket,..thanks very much for the help!
SamTherapy ( ) posted Mon, 16 July 2018 at 2:16 PM
I wonder if they are unconnected polys or Ngons. They sometimes render like that.
AnyMatter ( ) posted Mon, 16 July 2018 at 3:34 PM
yeah, i did suspect they are unconnected polys after setting up figure bones in setup room. 1 thing is that if i save it to figure library, poser will create a new identical geometry file obj in that library folder, but with seams visible around it like it was group separated or somtng.
rokket ( ) posted Mon, 16 July 2018 at 8:22 PM
I never would have thought about ngons. And I've only seen unconnected polys destroy a cloth sim. I guess Poser's smoothing and crease angle will expose modeling issues. Glad you fixed it.
CHK2033 ( ) posted Mon, 16 July 2018 at 8:37 PM
AnyMatter posted at 8:32PM Mon, 16 July 2018 - #4333241
Maybe it did check wait.... check his vid it may help https://www.youtube.com/watch?v=YikiP9pEAp4
HP Zbook 17 G6,  intel Xeon  64 GB of ram 1 TB SSD, Quadro RTX 5000
rokket ( ) posted Mon, 16 July 2018 at 10:06 PM
If you change the view in the main window to wire frame, that ngon will be visible. You will have to tessellate it into a quad.
CHK2033 ( ) posted Mon, 16 July 2018 at 10:54 PM
rokket what the hell man lol did you ever finish those wings?
rokket ( ) posted Tue, 17 July 2018 at 7:38 AM · edited Tue, 17 July 2018 at 7:38 AM
TheDarkerSideOfArt posted at 5:37AM Tue, 17 July 2018 - #4333257
Yeah, but they are on my laptop and I am forced to surf the web on the company's computers. So I can't post them...
