Sat, Nov 9, 8:20 PM CST
Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2024 Nov 04 10:44 pm)
banner
Subject: Walk Designer: Multiple Characters
mmandala ( ) posted Fri, 19 October 2018 at 11:54 PM · edited Sat, 09 November 2024 at 3:39 PM
Have a big project requiring multiple characters walking in scenes where they'll be ascending and descending wooded trails. The PZ3 file of the wooded area is already huge with a lot of plants and foliage which has caused a number of crashes already. I dread adding more character ploys to this already unstable build, but it's what the client is paying for. Question: should I design my character's walks in a separate file and import them OR render them with an alpha and composite them in AE or Motion? Thanks in advance!
Boni ( ) posted Sat, 20 October 2018 at 6:33 AM
Well, I would backup everything ... build each walk path and save it ... then slowly add each to your scene. IF and only if that crashes then I would composite it. When you composite it you will lose proper lighting and shadows, unless that is unnecessary. May I suggest you use a comic book style? I know that sounds weird, but it uses fewer resources and yuo may be able to do more. Your client might even enjoy the idea.
Boni
mmandala ( ) posted Sat, 20 October 2018 at 7:49 PM
Thank you, Boni! All good advice. I'm about to hit the Poser Manual to review animating walks, but off chance, can a walk path be made to go in the Y axis (up/down)?
Boni ( ) posted Sun, 21 October 2018 at 8:34 AM
That I am unsure of. But you can test it ... and "drop to ground" MIGHT help with that ... never tried it, though.
Boni
Richard60 ( ) posted Wed, 24 October 2018 at 9:02 PM
The walk path does not do Y, however you can manually go in and add the amount of Y need per frame or every some many frames depends on how curvy the terrain is.
mmandala ( ) posted Fri, 26 October 2018 at 3:01 PM
Richard60 posted at 3:01PM Fri, 26 October 2018 - #4338170
Thanks Richard!
