Fri, Jan 31, 2:07 AM CST
DAZ|Studio F.A.Q (Last Updated: 2025 Jan 30 6:38 pm)
Subject: to make Daz Studio Listen
goofygrape ( ) posted Fri, 30 November 2018 at 11:25 PM · edited Fri, 31 January 2025 at 1:41 AM
Studio only recognize the files in the folder Document's Studio my library. I used dim to download Daz3d 4.10,it placed the normal files in users public public documents my daz3d library.The question is how to get Studio to find my library?
Torquinox ( ) posted Sat, 01 December 2018 at 8:11 AM · edited Sat, 01 December 2018 at 8:12 AM
You can tell DIM where to put your files.
Click the gear in the top right corner, click Download tab and enter a new download directory in the spot marked Package Archive. You can also set thumbnail storage in Thumbnail Archive. Next click** Installation tab**. You can tell DIM where to store your Manifest archive. I think DIM uses that to remember what you have installed. Then you can add a custom content directory. That's where DIM puts your unzipped content files for DAZ to use.
Next go into DAZ Studio and hit f2 or click menu Edit -> Preferences. In the General tab, you can tell DAZ where to put your** temp files and DSON Cache files**. Then click Content tab -> Content Directory Manager. That dialog is weird, but click the + icons next to Daz Connect Data, Daz Studio Formats and Poser Formats then click on the locations in each section and press Edit on the vertical menu to the left. You'll get standard directory popup for your OS and you can tell Daz where to look for your content.
Be careful when you do these things. You can screw up your daz installation. You may need to move files around to match your new locations. Good luck!
goofygrape ( ) posted Sun, 02 December 2018 at 1:50 AM · edited Sun, 02 December 2018 at 1:51 AM
Ho Boy 😁 Thank's Torquinox
Torquinox ( ) posted Sun, 02 December 2018 at 9:59 AM
Any time :) If I may offer two words of advice: 1: Back up everything before you begin, just in case. 2: Don't delete any of the files. Instead, move them somewhere for easy monitoring and backup.
