Vue F.A.Q (Last Updated: 2024 Sep 14 4:17 pm)
Hi Catharina, I don't know what causes that except maybe that Vue 4 was designed based more on Poser 4 and not the PPP. I don't know that for certain, and it's just a guess. The only suggestion I have is from the E-on website: Find your Poser EXE filr and rename it from poser.exe to poser.exe. That's not a typing error, and yes it's the same name, but it seems to have worked for others for some reason. Maybe try the same thing with your PPP, as well. If that doesn't work, the only thing I could suggest is to contact support@e-onsoftware.com. They seem to have built a serial checker into Vue 4 when it comes to Poser, posibly as part of whatever deal they made with Curious Labs, but something seems to have gone wrong, when it comes to people using the PPP. Have you tried it with Poser 4 scenes, or only PPP?
Just a suggestion, as someone new to Poser and Vue, but when I did my installation I installed Poser first, and then installed Vue 4. When Vue4 was installing it asked for the location of poser.exe as i recall, after all that it worked fine and recognised the pz3 file no problem. It may be something very simple as the order of installation ie Poser then Vue, but thats my guess for the day!
Hello Catharina...this is Bill. What you can do and should work but I can't promise anything. When you Uninstall Poser and Vue 4, make sure you go to your Explorer manager and delete all the folder and files resifue related to Vue and Poser. If you have anything important in your "Poser Runtime" amke a copy of it (so tthat you don't have to rinastall all your model etc..again) and do the same for Vue Plants (Folder). After this, go to "regedit" thru "MSDOS" mode and look for anything that is Poser (Curiouslab) or Vue (e-on) files or sub folder under "Hkey/software" and have them deleted. Also checck your Windows "Temp" file and clear them. After this reboot and start your installation again and like Artic1 said, install Poser first, then Vue. This would ensure the installation is clean and that there are no instuctions from past installation from the Window registery. Works "Wholesale" for me all the time. If you still can't, like Mike say, there is a serialize check me check him thingy going on between CL and E-on, and in this case, you may have to get a new Serial number with CL which is a "must" registered copy...especially with PPP. Good luck. Alos make sure your PPP update is up to Service Pack 3 to avoid any problem. Good luck.
Hi Catharina, I'm too new to Vue to be an expert. I just thought I'd give you a possible solution just so you can get the PZ3 into the program. Vue seems quite quirky about how it works with Poser. At first it imported the PZ3's for me, then it didn't, now it does again. When it wouldn't accept the poser.exe location and refused to import the PZ3, I decided to try "load object" instead of "import object" and it brought the PZ3 in fine. Again due to the fact you're using propack this may or may not work but it's worth a try. droyd
I have Poser 4.03 and the ProPack with the lastest Service Update. I also have Vue4 with the 4.01 patch. I have the 4.02b patch as well, but I haven't installed it yet. I wanted to see what others said about it before I took the plunge, as 4.02 had problems. Anyway, I installed Poser first and then Vue, which I got later. I have never seen the error mentioned above. But I think I import my models by the method droyd mentioned above. I click on an icon on the left side of the screen about midway down. It opens a dialogbox with some models displayed in the middle. At the bottom are three buttons. I choose the one that says file and then I browse to the location where my pz3 file is. I've never had any problem with this. And if there's another way to bring a pz3 file in, I guess I didn't know it. Hope this method helps. Kevin
I'm pretty sure Catharina would be using the 4.03 Poser, but that reminds me of the Vue patches! Catharina, did you install the 4.01 patch for Vue 4? There are two patches for Vue 4: 4.01 and 4.02b. The 4.01 is necessry for fixing several of the Poser import difficulties that people were having. So if you don't already have the 4.01 patch on Vue, install that, then try the PZ3 import again. :)
Thank you to all for the help. Yes I have all what I need Vue 4: 4.01-4.02b Poser4.03 on LEGAL CD-R from Curious Labs and I don't have any time more to do all again, it cost me the whole day and I get well the big O, I will try in the next days again to fix the problem. I think what for idea from Vue and Curious Labs to do this to the user. there I get answer from Vue Support: Make sure you have the latest updates from Curious Labs. If that's the case and you still get the message, then it means that there is something wrong with your Poser Serial Number. You should contact Curious Labs. There's nothing we can do about that I'm afraid. Regards. ------------------- P.S Ok I must contact Curious Labs but WHY? I have problem with Vue and not with Poser4, they made the idiot serial number check in Vue and I am very angry. But HELLO I get some help from people into my e-mail and I hope I will fix this today. Thank you to all, Catharina
I don't know if this makes the difference or not. But I didn't know in my earlier post what the button I was clicking on was called, so I checked. I click on the Load Object button and then browse to where I store the Poser pz3 files. I see a list and I pick the one I want and it loads my poser model into the scene. It sounds to me like others use the import button. Right? If you haven't already, you might try both to see if either one makes a difference. But maybe the difference is the 4.02b patch. I haven't tried that yet. Kevin
Kevin, I generally use the Objects>Import way, but that's just because it's quicker than Objects>Load Object>File. Every now and then when I'm in a hurry I'll accidentally do it the second way, but there is no difference, at least on my machine. But, it is a good suggestion, and if there's one thing I've learned about Vue, is you just have to try different things. You know: Vue funny sometime, LOL!
I am using Vue 4 with patched, and Poser 4 with ProPack. When I try to import pz3 files Vue tells me that I have an invalid serial number of Poser. Anyone can help me with this problem? Thank you so much! Catharina
