DAZ|Studio F.A.Q (Last Updated: 2025 Feb 12 6:12 pm)
Unless the Poser 6 runtime doesn't exist on the hard drive, it is not necessary to create a copy. You can always create a path for both libraries, however, the newer content in DAZStudio will not appear in Poser. And Poser 6 is not optimal for DSON if you wanted to import Genesis into Poser as a figure.
Were you trying to run Poser items in DAZ, or DAZ items in Poser? If you are just trying to link to the Poser Library in DAZ as hborre said, all you need to do is set up another library link from the Edit panel as I recall. DAZ allows you to use as many libraries as you want. The two programs are growing further apart though, the older stuff works well except for dynamic anything, shaders, and mt5 format materials. Newer stuff is kind of hit and miss and takes more massaging particularly figures.
I have been setting up a new computer. In the past I have always insalled my Poser 6 with any version of Daz Studio I was using. Can I just take a copy of my Poser 6 Runtime floder and place it on the hard drive? Can you create a path from the Daz Content Libary to the Poser Runtime Folder content? Will the files load as Poser content?
