I presume you tried the same way that I did: Make an image with text, import the image into either the terrain editor or as a symmetrical lattice, trim off the black. I'm not totally sure why there are rough edges. My perception is that text images created using normal fonts don't have enough smoothness. There's a KPT plug-in that can be used to smooth the picture, but its difficult to make smooth text in Bryce.
yes I did that heh, what I do is make a 512 x 512 pixels greyscale image in photoshop at 150 dpi, save it as a .tif file then import that into the TE and set it to 512 or higher. It works in versions 3-5 so if you have Bryce 4 it'll still work the same way:-) Hope that helps ya out.
Do atleast one thing a day that scares the hell outta ya!!
Without the use of any 3D text rendering freeware or shareware plugins or applications I've read terrain Editor tutorial and have been trying to render 3D text from within Bryce3. But I always get these rough edges, can anybody explain the reason? = )
