Tue, Nov 19, 12:30 PM CST
Subject: Poser animated textures?
PhotinoBird ( ) posted Sun, 24 March 2019 at 1:21 PM · edited Mon, 18 November 2024 at 8:47 AM
Is there a way to make animated 2D textures in Poser Pro 11? Think Wind Waker's face animation.
ironsoul ( ) posted Sun, 24 March 2019 at 4:36 PM
If its a just a couple of 2D textures then a Blender node might be an answer. Attached the two images to the blender node and then animate the "Blending" parameter. Blender nodes could be cascaded to support more than two but it starts to get complicated.
There is also a movie node that allows AVI to be imported with a frame_number input which possibly could be driven by an animated math node but never tried it.
ironsoul ( ) posted Sun, 24 March 2019 at 5:08 PM · edited Sun, 24 March 2019 at 5:09 PM
Example of math node selecting a frame from an AVI - the idea is the different textures are stored in the AVI one per frame and the animated math function selects the frame. As mentioned, never tried it so may have its own problems
ironsoul ( ) posted Sun, 24 March 2019 at 5:54 PM
Maybe I've misunderstood you're question, my response is to do with projecting a 2D animation onto a 3D model, if you're question was about creating a 2D like animation using Poser that would be require another answer.
PhotinoBird ( ) posted Sun, 24 March 2019 at 7:00 PM
Thank you for the help.
seachnasaigh ( ) posted Sun, 24 March 2019 at 7:30 PM · edited Sun, 24 March 2019 at 7:31 PM
I'm not sure what OP wants either; here is another idea: Use a series of sequentially numbered JPEGs in the movie node to control color and displacement as the animation progresses.
Render result:
Atlantis stargate - event horizon puddle
operaguy ( ) posted Sun, 24 March 2019 at 7:49 PM
I don't know if the OP is getting what's needed, but I sure am. I've wanted to learn how to do this for a long time.
Can you animate transparency? Just have a character walking along and fading to nothing?
seachnasaigh ( ) posted Mon, 25 March 2019 at 6:34 AM
operaguy posted at 6:32AM Mon, 25 March 2019 - #4348730
Yes, simply use the animated texture to control transparency. :D I'll make a demo.
operaguy ( ) posted Mon, 25 March 2019 at 9:09 AM
Thanks, I've wanted to learn to animate transparency for a long time.
seachnasaigh ( ) posted Mon, 25 March 2019 at 9:42 AM · edited Mon, 25 March 2019 at 9:44 AM
In the runtime\textures folder, create a folder just for the sequentially numbered JPEGs...
Here is the material setup I used; the nodes along the bottom were just adjusting the greyscale level to serve as a transparency map, because I was too lazy to make a corresponding set of transmap JPEGs. 😄 You'd not need that, or the sine wave node group, nor the lightcasting boost node group.
-> animated transparency GIF <-
Still frame render:
The material can be applied to a doll...
operaguy ( ) posted Mon, 25 March 2019 at 10:31 AM · edited Mon, 25 March 2019 at 10:33 AM
seachnasaigh, that is amazing tech. I have to study it to grasp it.
Can you or anyone add one thing:
Without an image sequence folder, is it possible to simply have Poser walk through a 100-frame animation of a ball and the transparency node increments automatically from 0.00 to 1.00?
seachnasaigh ( ) posted Mon, 25 March 2019 at 10:48 AM
operaguy posted at 10:46AM Mon, 25 March 2019 - #4348781
Yes. Look for the "key" icon next to the transparency value; set it at 0 in frame 001, then go to frame 30 and set transparency value to 1. That will keyframe the transparency in your timeline.
operaguy ( ) posted Mon, 25 March 2019 at 10:58 AM
OMG! Thank you. [please don't tell me that is in the Poser manual, but I bet it is.]
