Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 01 7:14 pm)
Sorry.This might read a bit clearer.Cheers
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses. Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
Many thanks for your reply.I am sorry but I do not understand what you mean! Do I have to change settings on my computer or are you suggesting it is just the one character only with this import problem? Every time I open or import a Genesis 2 figure I am getting a similar popup.Any help appreciated. Cheers
OK.Many thanks. Cheers
Looking at reports from other users this can happen if a figure attempts to load morphs not installed. The suggestion is to look at the DSON log file. It might be worth checking the log file to see if it contains more information
On my machine the log file is located
C:\Users\myusername\AppData\Roaming\DAZ 3D\DsonPoser\log.txt
To find where your DSON install directory, select Scripts->DSON Support->Importer Preferences. The cache folder is display which will show the location of the DAZ 3D folder.
Once again many thanks for your replies.I have checked the log file and you are correct! It is trying to load morphs.When you say they are not installed does that mean in DAZ Studio or Poser? Cheers
I have all the figures and morphs in the same runtime and I am still having problems with importing Genesis 2 Female into Poser Pro 11!.I have logged the problem at DAZ.I will post here if I get a reply! Cheers
Many Thanks RobZhena for your reply.Could I be a nuisance and ask do I put this script into my main Poser Program files or can I put it into my main runtime in which is on a portable hard drive? Cheers
PS.I am referring to Runtime/Python/Poser scripts/ScriptsMenu/D3D/> either in Poser exe or my usable runtime? Cheers
Thanks. It sort of works.It will bring a Genesis 2 Female figure in but it does not bring the textures with it and I am still getting a unicode error! I will see what DAZ has to say! Cheers
Per the thread above, you could try D3D's free DSON Loader. The other way to go is just stop screwing with DSON. Export the cr2 from DAZ and then convert it to Poser native format using Netherwork's Creator's Toybox (the file optimizer), available at Hivewire. The instructions explain clearly how to do that. I convert ALL my DSON cr2s to Poser native so I don'y have to suffer DSON lag and the practical limits on how many figures you can have in a scene at one time. I also export "DAZ only" products and do the same.
Can anyone tell me what this means and what I am doing wrong?
