Fri, Nov 22, 8:27 PM CST
Subject: Is it possible to script Master parameter injections?
vholf ( ) posted Wed, 26 June 2019 at 4:23 PM · edited Fri, 22 November 2024 at 8:22 PM
Hi there. I'm using Poser 11 Pro and I created a bunch of master parameters in a figure to control multiple actions (eg: one dial controls, arms, torso and legs). This are quite handy and I would like to have them in other figures (same base figure, just a different CR2). Is it possible to extract this master parameters and inject them into another figure? is it scriptable?
Thanks!
unrealblue ( ) posted Wed, 26 June 2019 at 7:59 PM
Ah... Just the question I was looking for an answer to :D
Can you save a master as a "pose" and have it load by simply clicking that saved pose? Does poser automatically wire that up?
I wouldn't expect it to load the needed morphs, although that would be cool... but how would it determine which files contain the applicable morphs?
I'm going to try saving a master that wires up some of La Femme control chips, then save (only) the resulting master, then apply that to a La Femme figure that doesn't have that master. Back later to post how it went.
unrealblue ( ) posted Wed, 26 June 2019 at 11:30 PM · edited Wed, 26 June 2019 at 11:31 PM
And the answer is: no, it doesn't work simply saving the morphs though the GUI. At least, not that I could find. Sorry. There are other's who've forgotten more than I will ever know about Poser, though, so maybe there is a way to do that.
As for scriptable, pretty sure it is. And I think scripts can be triggered by a library entry. iirc, some of the v4wm's do that, as well as commercially available joint fix injections (for v4). I'm working on a script that will take a bunch of La Femme face chip settings and turn them into a single master. It's tedious in the extreme wiring dozens of parameters through the GUI. It's tedious enough messing working with those parameters to get the expression (pose) in the first place. Need a one button (save facial pose as expression). Soon :)
an0malaus ( ) posted Thu, 27 June 2019 at 12:13 AM
Hioushi & thoennes, yes, this is eminently doable. The trick is simply to put the normal contents of a character CR2 file within a pose PZ2 file. In other words, you include all of the name, limit and especially ERC and delta (if you're adding morphTargets) information that would be in a CR2 and is usually left out of a PZ2 file.
I've created such a thing for adding extra master parameters to PE. Additionally, where a CR2 would make reference to a figureResFile, in its place, you put the PZ2 targetFIgure line which identifies which figure the pose is intended for. The targetFigure value is basically just the name of the OBJ file that the figureResFile would refer to, but without the full path and .OBJ extension.
The pose only needs to refer to the actors which you're adding master channels or valueOperations (ERC) to, and doesn't need a figure block at all.
My ShareCG Stuff
Verbosity: Profusely promulgating Graham's number epics of complete and utter verbiage by the metric monkey barrel.
an0malaus ( ) posted Thu, 27 June 2019 at 12:16 AM
Here's the example for PE I was referring to (save as "Add Arm Orbit ERC.pz2"):
version
    number 11
    build 34764
thighLength 0.186251
targetFigure Evolution.Base.14h5
actor BODY:1
    groups
        groupNode Morphforms
            groupNode Arms
                collapsed 1
                parmNode CTRLArmsEnableShrug
                parmNode CTRLArmsOrbit
                parmNode CTRLArmOrbitL
                parmNode CTRLArmOrbitR
                parmNode CTRLArmsPhase
                parmNode CTRLArmPhaseL
                parmNode CTRLArmPhaseR
                parmNode CTRLArmsFold
                parmNode CTRLArmFoldL
                parmNode CTRLArmFoldR
                parmNode CTRLArmOrbitUp-DownL
                parmNode CTRLArmOrbitUp-DownR
                parmNode CTRLArmOrbitFront-BackL
                parmNode CTRLArmOrbitFront-BackR
                parmNode CTRLArmsRoll
                parmNode CTRLArmsScissor
                parmNode CTRLArmsSwivel
                parmNode CTRLArmsTwist
                parmNode CTRLArmsUp-Down
                parmNode CTRLArmUp-DownL
                parmNode CTRLArmUp-DownR
                parmNode CTRLShouldersShrug
                parmNode CTRLShoulderShrugL
                parmNode CTRLShoulderShrugR
                parmNode CTRLCollarsFront-Back
                parmNode CTRLCollarFront-BackL
                parmNode CTRLCollarFront-BackR
                parmNode CTRLCollarsTwist
                parmNode CTRLElbowsBend
                parmNode CTRLElbowBendL
                parmNode CTRLElbowBendR
                parmNode CTRLElbowsScissor
                parmNode CTRLElbowsSwivel
                parmNode CTRLHandsBend
                parmNode CTRLHandsSide-Side
                parmNode CTRLHandsTwist
                parmNode CTRLHandsRoll
                parmNode CTRLHandsScissor
                parmNode CTRLHandsSwivel
                parmNode CTRLPalmsTwist
                groupNode Fingers
                    collapsed 1
                    parmNode CTRLHandGrasp
                    parmNode CTRLHandSpread
                    parmNode CTRLFingersRoll
                    parmNode CTRLFingersScissor
                    parmNode CTRLFingersSwivel
                    parmNode CTRLFingersYaw
                    parmNode CTRLThumbOppose
                    parmNode CTRLThumbSpread
                    parmNode CTRLThumbGrasp
                    parmNode CTRLIndexGrasp
                    parmNode CTRLMiddleGrasp
                    parmNode CTRLRingGrasp
                    parmNode CTRLPinkyGrasp
                    groupNode Claws
                        collapsed 1
                        parmNode CTRLHandClaw
                        parmNode CTRLThumbClaw
                        parmNode CTRLIndexClaw
                        parmNode CTRLMiddleClaw
                        parmNode CTRLRingClaw
                        parmNode CTRLPinkyClaw
        groupNode Morphs | Partial (Hidden)
            collapsed 1
            parmNode PlusArmOrbitR
            parmNode MinusArmOrbitR
            parmNode AbsArmOrbitR
            parmNode PlusArmOrbitL
            parmNode MinusArmOrbitL
            parmNode AbsArmOrbitL
            parmNode ShrugRatioR
            parmNode ShrugRatioL
            parmNode ShrugFactorR
            parmNode ShrugFactorL
    channels
        valueParm CTRLArmsEnableShrug
            name ArmsEnableShrug
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min 0
            max 1
            trackingScale 1
            masterSynched 0
            keys
                static  0
                k  0  0
            interpStyleLocked 0
        valueParm CTRLArmsOrbit
            name ArmsOrbit
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -3//-2.2//-2
            max 3//2.2//2
            trackingScale 0.0222222
            masterSynched 0
            keys
                static  0
                k  0  0
            interpStyleLocked 0
        valueParm CTRLArmOrbitL
            name ArmOrbitL
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -3//-2.2//-2
            max 3//2.2//2
            masterSynched 1
            keys
                static  0
                k  0  0
            interpStyleLocked 0
            valueOpDeltaAdd
                Figure 1
                BODY:1
                CTRLArmsOrbit
            strength 1.000000
            deltaAddDelta 1.000000
        valueParm CTRLArmOrbitR
            name ArmOrbitR
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -3//-2.2//-2
            max 3//2.2//2
            masterSynched 1
            keys
                static  0
                k  0  0
            interpStyleLocked 0
            valueOpDeltaAdd
                Figure 1
                BODY:1
                CTRLArmsOrbit
            strength 1.000000
        valueParm CTRLArmsPhase
            name ArmsPhase
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -360
            max 360
            trackingScale 1
            masterSynched 0
            keys
                static  0
                k  0  0
            interpStyleLocked 0
        valueParm CTRLArmPhaseL
            name ArmPhaseL
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -360
            max 360
            trackingScale 1
            masterSynched 1
            keys
                static  0
                k  0  0
            interpStyleLocked 0
            valueOpDeltaAdd
                Figure 1
                BODY:1
                CTRLArmsPhase
            strength 1.000000
            valueOpDeltaAdd
                Figure 1
                BODY:1
                CTRLArmFoldL
            strength 1.000000
        valueParm CTRLArmPhaseR
            name ArmPhaseR
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -360
            max 360
            trackingScale 1
            masterSynched 1
            keys
                static  0
                k  0  0
            interpStyleLocked 0
            valueOpDeltaAdd
                Figure 1
                BODY:1
                CTRLArmsPhase
            strength 1.000000
            valueOpDeltaAdd
                Figure 1
                BODY:1
                CTRLArmFoldR
            strength 1.000000
        valueParm CTRLArmsFold
            name ArmsFold
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -37.5
            max 150
            trackingScale 1
            masterSynched 0
            keys
                static  0
                k  0  0
            interpStyleLocked 0
        valueParm CTRLArmFoldL
            name ArmFoldL
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -37.5
            max 150
            trackingScale 1
            masterSynched 1
            keys
                static  0
                k  0  0
            interpStyleLocked 0
            valueOpDeltaAdd
                Figure 1
                BODY:1
                CTRLArmsFold
            strength 1.000000
        valueParm CTRLArmFoldR
            name ArmFoldR
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -37.5
            max 150
            trackingScale 1
            masterSynched 1
            keys
                static  0
                k  0  0
            interpStyleLocked 0
            valueOpDeltaAdd
                Figure 1
                BODY:1
                CTRLArmsFold
            strength 1.000000
        valueParm CTRLArmOrbitUp-DownL
            name ArmOrbitUp-DownL
            initValue 0
            hidden 1
            enabled 1
            forceLimits 1
            min -3//-2.2//-2
            max 3//2.2//2
            trackingScale 0.01
            masterSynched 1
            keys
                static  0
                k  0  0
            interpStyleLocked 0
            valueOpKey
                Figure 1
                BODY:1
                CTRLArmPhaseL
            strength 1.000000
                beginValueKeys
                    valueKey -370 0.984808
                    valueKey -360 1
                    valueKey -350 0.984808
                    valueKey -340 0.939693
                    valueKey -330 0.866025
                    valueKey -320 0.766044
                    valueKey -310 0.642788
                    valueKey -300 0.5
                    valueKey -290 0.34202
                    valueKey -280 0.173648
                    valueKey -270 -1.83697e-16
                    valueKey -260 -0.173648
                    valueKey -250 -0.34202
                    valueKey -240 -0.5
                    valueKey -230 -0.642788
                    valueKey -220 -0.766044
                    valueKey -210 -0.866025
                    valueKey -200 -0.939693
                    valueKey -190 -0.984808
                    valueKey -180 -1
                    valueKey -170 -0.984808
                    valueKey -160 -0.939693
                    valueKey -150 -0.866025
                    valueKey -140 -0.766044
                    valueKey -130 -0.642788
                    valueKey -120 -0.5
                    valueKey -110 -0.34202
                    valueKey -100 -0.173648
                    valueKey -90 6.12323e-17
                    valueKey -80 0.173648
                    valueKey -70 0.34202
                    valueKey -60 0.5
                    valueKey -50 0.642788
                    valueKey -40 0.766044
                    valueKey -30 0.866025
                    valueKey -20 0.939693
                    valueKey -10 0.984808
                    valueKey 0 1
                    valueKey 10 0.984808
                    valueKey 20 0.939693
                    valueKey 30 0.866025
                    valueKey 40 0.766044
                    valueKey 50 0.642788
                    valueKey 60 0.5
                    valueKey 70 0.34202
                    valueKey 80 0.173648
                    valueKey 90 6.12323e-17
                    valueKey 100 -0.173648
                    valueKey 110 -0.34202
                    valueKey 120 -0.5
                    valueKey 130 -0.642788
                    valueKey 140 -0.766044
                    valueKey 150 -0.866025
                    valueKey 160 -0.939693
                    valueKey 170 -0.984808
                    valueKey 180 -1
                    valueKey 190 -0.984808
                    valueKey 200 -0.939693
                    valueKey 210 -0.866025
                    valueKey 220 -0.766044
                    valueKey 230 -0.642788
                    valueKey 240 -0.5
                    valueKey 250 -0.34202
                    valueKey 260 -0.173648
                    valueKey 270 -1.83697e-16
                    valueKey 280 0.173648
                    valueKey 290 0.34202
                    valueKey 300 0.5
                    valueKey 310 0.642788
                    valueKey 320 0.766044
                    valueKey 330 0.866025
                    valueKey 340 0.939693
                    valueKey 350 0.984808
                    valueKey 360 1
                    valueKey 370 0.984808
                endValueKeys
            valueOpTimes
                Figure 1
                BODY:1
                CTRLArmOrbitL
            strength 1.000000
        valueParm CTRLArmOrbitUp-DownR
            name ArmOrbitUp-DownR
            initValue 0
            hidden 1
            enabled 1
            forceLimits 1
            min -3//-2.2//-2
            max 3//2.2//2
            trackingScale 0.01
            masterSynched 1
            keys
                static  0
                k  0  0
            interpStyleLocked 0
            valueOpKey
                Figure 1
                BODY:1
                CTRLArmPhaseR
            strength 1.000000
                beginValueKeys
                    valueKey -360 1
                    valueKey -300 0.5
                    valueKey -240 -0.5
                    valueKey -180 -1
                    valueKey -120 -0.5
                    valueKey -60 0.5
                    valueKey 0 1
                    valueKey 60 0.5
                    valueKey 70 0.34202
                    valueKey 120 -0.5
                    valueKey 180 -1
                    valueKey 240 -0.5
                    valueKey 300 0.5
                    valueKey 360 1
                endValueKeys
            valueOpTimes
                Figure 1
                BODY:1
                CTRLArmOrbitR
            strength 1.000000
        valueParm CTRLArmOrbitFront-BackL
            name ArmOrbitFront-BackL
            initValue 0
            hidden 1
            enabled 1
            forceLimits 1
            min -3//-2.2//-2
            max 3//2.2//2
            trackingScale 0.01
            masterSynched 1
            keys
                static  0
                k  0  0
            interpStyleLocked 0
            valueOpKey
                Figure 1
                BODY:1
                CTRLArmPhaseL
            strength 1.000000
                beginValueKeys
                    valueKey -370 -0.173648
                    valueKey -360 2.44929e-16
                    valueKey -350 0.173648
                    valueKey -340 0.34202
                    valueKey -330 0.5
                    valueKey -320 0.642788
                    valueKey -310 0.766044
                    valueKey -300 0.866025
                    valueKey -290 0.939693
                    valueKey -280 0.984808
                    valueKey -270 1
                    valueKey -260 0.984808
                    valueKey -250 0.939693
                    valueKey -240 0.866025
                    valueKey -230 0.766044
                    valueKey -220 0.642788
                    valueKey -210 0.5
                    valueKey -200 0.34202
                    valueKey -190 0.173648
                    valueKey -180 -1.22465e-16
                    valueKey -170 -0.173648
                    valueKey -160 -0.34202
                    valueKey -150 -0.5
                    valueKey -140 -0.642788
                    valueKey -130 -0.766044
                    valueKey -120 -0.866025
                    valueKey -110 -0.939693
                    valueKey -100 -0.984808
                    valueKey -90 -1
                    valueKey -80 -0.984808
                    valueKey -70 -0.939693
                    valueKey -60 -0.866025
                    valueKey -50 -0.766044
                    valueKey -40 -0.642788
                    valueKey -30 -0.5
                    valueKey -20 -0.34202
                    valueKey -10 -0.173648
                    valueKey 0 0
                    valueKey 10 0.173648
                    valueKey 20 0.34202
                    valueKey 30 0.5
                    valueKey 40 0.642788
                    valueKey 50 0.766044
                    valueKey 60 0.866025
                    valueKey 70 0.939693
                    valueKey 80 0.984808
                    valueKey 90 1
                    valueKey 100 0.984808
                    valueKey 110 0.939693
                    valueKey 120 0.866025
                    valueKey 130 0.766044
                    valueKey 140 0.642788
                    valueKey 150 0.5
                    valueKey 160 0.34202
                    valueKey 170 0.173648
                    valueKey 180 1.22465e-16
                    valueKey 190 -0.173648
                    valueKey 200 -0.34202
                    valueKey 210 -0.5
                    valueKey 220 -0.642788
                    valueKey 230 -0.766044
                    valueKey 240 -0.866025
                    valueKey 250 -0.939693
                    valueKey 260 -0.984808
                    valueKey 270 -1
                    valueKey 280 -0.984808
                    valueKey 290 -0.939693
                    valueKey 300 -0.866025
                    valueKey 310 -0.766044
                    valueKey 320 -0.642788
                    valueKey 330 -0.5
                    valueKey 340 -0.34202
                    valueKey 350 -0.173648
                    valueKey 360 -2.44929e-16
                    valueKey 370 0.173648
                endValueKeys
            valueOpTimes
                Figure 1
                BODY:1
                CTRLArmOrbitL
            strength 1.000000
        valueParm CTRLArmOrbitFront-BackR
            name ArmOrbitFront-BackR
            initValue 0
            hidden 1
            enabled 1
            forceLimits 1
            min -3//-2.2//-2
            max 3//2.2//2
            trackingScale 0.01
            masterSynched 1
            keys
                static  0
                k  0  0
            interpStyleLocked 0
                valueOpKey
                Figure 1
                BODY:1
                CTRLArmPhaseR
            strength 1.000000
                beginValueKeys
                    valueKey -330 0.5
                    valueKey -270 1
                    valueKey -210 0.5
                    valueKey -150 -0.5
                    valueKey -90 -1
                    valueKey -30 -0.5
                    valueKey 0 0
                    valueKey 20 0.34202
                    valueKey 30 0.5
                    valueKey 90 1
                    valueKey 150 0.5
                    valueKey 210 -0.5
                    valueKey 270 -1
                    valueKey 330 -0.5
                endValueKeys
            valueOpTimes
                Figure 1
                BODY:1
                CTRLArmOrbitR
            strength 1.000000
        valueParm CTRLArmsRoll
            name ArmsRoll
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -2
            max 2
            trackingScale 0.05
            masterSynched 0
            keys
                static  0
                k  0  0
            interpStyleLocked 0
        valueParm CTRLArmsScissor
            name ArmsScissor
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -4
            max 4
            trackingScale 0.1
            masterSynched 0
            keys
                static  0
                k  0  0
            interpStyleLocked 0
        valueParm CTRLArmsSwivel
            name ArmsSwivel
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -2
            max 2
            trackingScale 0.05
            masterSynched 0
            keys
                static  0
                k  0  0
            interpStyleLocked 0
        valueParm CTRLArmsTwist
            name ArmsTwist
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -1.4//-1.1
            max 0.8
            trackingScale 0.01
            masterSynched 0
            keys
                static  0
                k  0  0
            interpStyleLocked 0
        valueParm CTRLArmsUp-Down
            name ArmsUp-Down
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -2
            max 2
            trackingScale 0.05
            masterSynched 0
            keys
                static  0
                k  0  0
            interpStyleLocked 0
        valueParm CTRLArmUp-DownL
            name ArmUp-DownL
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -2
            max 2
            trackingScale 0.05
            masterSynched 0
            keys
                static  0
                k  0  0
            interpStyleLocked 0
            valueOpDeltaAdd
                Figure 1
                BODY:1
                CTRLArmsUp-Down
            strength 1.000000
            valueOpDeltaAdd
                Figure 1
                BODY:1
                CTRLArmsRoll
            strength 1.000000
            valueOpDeltaAdd
                Figure 1
                BODY:1
            strength 1.000000
        valueParm CTRLArmUp-DownR
            name ArmUp-DownR
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -2
            max 2
            trackingScale 0.05
            masterSynched 0
            keys
                static  0
                k  0  0
            interpStyleLocked 0
            valueOpDeltaAdd
                Figure 1
                BODY:1
                CTRLArmsUp-Down
            strength 1.000000
            valueOpDeltaAdd
                Figure 1
                BODY:1
                CTRLArmsRoll
            strength -1.000000
            deltaAddDelta -1.000000
            valueOpDeltaAdd
                Figure 1
                BODY:1
            strength 1.000000
        valueParm CTRLShouldersShrug
            name ShouldersShrug
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -1
            max 2
            trackingScale 0.0833333
            masterSynched 1
            keys
                static  0
                k  0  0
            interpStyleLocked 0
        valueParm CTRLShoulderShrugL
            name ShoulderShrugL
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -1
            max 2
            masterSynched 1
            keys
                static  0
                k  0  0
            interpStyleLocked 0
            valueOpDeltaAdd
                Figure 1
                BODY:1
                CTRLShouldersShrug
            strength 1.000000
            valueOpTimes
                Figure 1
                BODY:1
                ShrugFactorL
            strength 1.000000
        valueParm CTRLShoulderShrugR
            name ShoulderShrugR
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -1
            max 2
            masterSynched 1
            keys
                static  0
                k  0  0
            interpStyleLocked 0
            valueOpDeltaAdd
                Figure 1
                BODY:1
                CTRLShouldersShrug
            strength 1.000000
            valueOpTimes
                Figure 1
                BODY:1
                ShrugFactorR
            strength 1.000000
        valueParm CTRLCollarsFront-Back
            name CollarsFront-Back
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -4
            max 3
            trackingScale 0.1
            masterSynched 0
            keys
                static  0
                k  0  0
            interpStyleLocked 0
        valueParm CTRLCollarFront-BackL
            name CollarFront-BackL
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -4
            max 3
            trackingScale 0.1
            masterSynched 1
            keys
                static  0
                k  0  0
            interpStyleLocked 0
            valueOpDeltaAdd
                Figure 1
                BODY:1
            strength 1.000000
        valueParm CTRLCollarFront-BackR
            name CollarFront-BackR
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -4
            max 3
            trackingScale 0.1
            masterSynched 1
            keys
                static  0
                k  0  0
            interpStyleLocked 0
            valueOpDeltaAdd
                Figure 1
                BODY:1
            strength 1.000000
        valueParm CTRLCollarsTwist
            name CollarsTwist
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -4
            max 3
            trackingScale 0.1
            masterSynched 0
            keys
                static  0
                k  0  0
            interpStyleLocked 0
        valueParm CTRLElbowsBend
            name ElbowsBend
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -0.25
            max 1.5
            trackingScale 0.01
            masterSynched 0
            keys
                static  0
                k  0  0
            interpStyleLocked 0
        valueParm CTRLElbowBendL
            name ElbowBendL
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -0.375
            max 1.5
            trackingScale 0.01
            masterSynched 1
            keys
                static  0
                k  0  0
            interpStyleLocked 0
            valueOpDeltaAdd
                Figure 1
                BODY:1
                CTRLElbowsBend
            strength 1.000000
            valueOpDeltaAdd
                Figure 1
                BODY:1
                CTRLElbowsScissor
            strength -1.000000
            valueOpDeltaAdd
                Figure 1
                BODY:1
                CTRLArmFoldL
            strength 0.020000
            deltaAddDelta 0.020000
        valueParm CTRLElbowBendR
            name ElbowBendR
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -0.375
            max 1.5
            trackingScale 0.01
            masterSynched 1
            keys
                static  0
                k  0  0
            interpStyleLocked 0
            valueOpDeltaAdd
                Figure 1
                BODY:1
                CTRLElbowsBend
            strength 1.000000
            valueOpDeltaAdd
                Figure 1
                BODY:1
                CTRLElbowsScissor
            strength 1.000000
            valueOpDeltaAdd
                Figure 1
                BODY:1
                CTRLArmFoldR
            strength 0.020000
        valueParm CTRLElbowsScissor
            name ElbowsScissor
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -1.5
            max 1.5
            trackingScale 0.01
            masterSynched 0
            keys
                static  0
                k  0  0
            interpStyleLocked 0
        valueParm CTRLElbowsSwivel
            name ElbowsSwivel
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -1.4//-1.1
            max 1.4//1.1
            trackingScale 0.01
            masterSynched 0
            keys
                static  0
                k  0  0
            interpStyleLocked 0
        valueParm CTRLHandsBend
            name HandsBend
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -0.65
            max 0.7
            trackingScale 0.01
            masterSynched 0
            keys
                static  0
                k  0  0
            interpStyleLocked 0
        valueParm CTRLHandsSide-Side
            name HandsSide-Side
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -0.25
            max 0.2
            trackingScale 0.01
            masterSynched 0
            keys
                static  0
                k  0  0
            interpStyleLocked 0
        valueParm CTRLHandsTwist
            name HandsTwist
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -1
            max 1//0.7
            trackingScale 0.01
            masterSynched 0
            keys
                static  0
                k  0  0
            interpStyleLocked 0
        valueParm CTRLHandsRoll
            name HandsRoll
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -0.7
            max 0.7
            trackingScale 0.01
            masterSynched 0
            keys
                static  0
                k  0  0
            interpStyleLocked 0
        valueParm CTRLHandsScissor
            name HandsScissor
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -0.25
            max 0.25
            trackingScale 0.01
            masterSynched 0
            keys
                static  0
                k  0  0
            interpStyleLocked 0
        valueParm CTRLHandsSwivel
            name HandsSwivel
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -1//-0.7
            max 1//0.7
            trackingScale 0.01
            masterSynched 0
            keys
                static  0
                k  0  0
            interpStyleLocked 0
        valueParm CTRLPalmsTwist
            name PalmsTwist
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -0.1
            max 0.1
            trackingScale 0.01
            masterSynched 0
            keys
                static  0
                k  0  0
            interpStyleLocked 0
        valueParm CTRLHandGrasp
            name Grasp
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -1
            max 2
            trackingScale 0.02
            masterSynched 0
            keys
                static  0
                k  0  0
            interpStyleLocked 0
        valueParm CTRLHandSpread
            name Spread
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -1
            max 1
            trackingScale 0.02
            masterSynched 0
            keys
                static  0
                k  0  0
            interpStyleLocked 0
        valueParm CTRLFingersRoll
            name FingersRoll
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -1
            max 1
            trackingScale 0.02
            masterSynched 0
            keys
                static  0
                k  0  0
            interpStyleLocked 0
        valueParm CTRLFingersScissor
            name FingersScissor
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -1
            max 1
            trackingScale 0.02
            masterSynched 0
            keys
                static  0
                k  0  0
            interpStyleLocked 0
        valueParm CTRLFingersSwivel
            name FingersSwivel
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -1
            max 1
            trackingScale 0.02
            masterSynched 0
            keys
                static  0
                k  0  0
            interpStyleLocked 0
        valueParm CTRLFingersYaw
            name FingersYaw
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -0.15
            max 0.15
            trackingScale 0.01
            masterSynched 0
            keys
                static  0
                k  0  0
            interpStyleLocked 0
        valueParm CTRLThumbOppose
            name ThumbOppose
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min 0
            max 1.5
            trackingScale 0.0125
            masterSynched 0
            keys
                static  0
                k  0  0
            interpStyleLocked 0
        valueParm CTRLThumbSpread
            name ThumbSpread
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -1.5
            max 2
            trackingScale 0.02
            masterSynched 0
            keys
                static  0
                k  0  0
            interpStyleLocked 0
        valueParm CTRLThumbGrasp
            name ThumbGrasp
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -0.5
            max 1
            trackingScale 0.02
            masterSynched 0
            keys
                static  0
                k  0  0
            interpStyleLocked 0
        valueParm CTRLIndexGrasp
            name IndexGrasp
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -1
            max 2
            trackingScale 0.02
            masterSynched 0
            keys
                static  0
                k  0  0
            interpStyleLocked 0
        valueParm CTRLMiddleGrasp
            name MiddleGrasp
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -1
            max 2
            trackingScale 0.02
            masterSynched 0
            keys
                static  0
                k  0  0
            interpStyleLocked 0
        valueParm CTRLRingGrasp
            name RingGrasp
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -1
            max 2
            trackingScale 0.02
            masterSynched 0
            keys
                static  0
                k  0  0
            interpStyleLocked 0
        valueParm CTRLPinkyGrasp
            name PinkyGrasp
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -1
            max 2
            trackingScale 0.02
            masterSynched 0
            keys
                static  0
                k  0  0
            interpStyleLocked 0
        valueParm CTRLHandClaw
            name Claw
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -1
            max 2
            trackingScale 0.02
            masterSynched 0
            keys
                static  0
                k  0  0
            interpStyleLocked 0
        valueParm CTRLThumbClaw
            name ThumbClaw
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -0.5
            max 1
            trackingScale 0.02
            masterSynched 0
            keys
                static  0
                k  0  0
            interpStyleLocked 0
        valueParm CTRLIndexClaw
            name IndexClaw
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -1
            max 2
            trackingScale 0.02
            masterSynched 0
            keys
                static  0
                k  0  0
            interpStyleLocked 0
        valueParm CTRLMiddleClaw
            name MiddleClaw
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -1
            max 2
            trackingScale 0.02
            masterSynched 0
            keys
                static  0
                k  0  0
            interpStyleLocked 0
        valueParm CTRLRingClaw
            name RingClaw
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -1
            max 2
            trackingScale 0.02
            masterSynched 0
            keys
                static  0
                k  0  0
            interpStyleLocked 0
        valueParm CTRLPinkyClaw
            name PinkyClaw
            initValue 0
            hidden 0
            enabled 1
            forceLimits 1
            min -1
            max 2
            trackingScale 0.02
            masterSynched 0
            keys
                static  0
                k  0  0
            interpStyleLocked 0
        valueParm PlusArmOrbitR
            name PlusArmOrbitR
            initValue 0
            hidden 1
            enabled 1
            forceLimits 1
            min 0
            max 2.2
            trackingScale 0.01
            masterSynched 1
            keys
                static  0
                k  0  0
            interpStyleLocked 0
            valueOpDeltaAdd
                Figure 1
                BODY:1
                CTRLArmOrbitR
            strength 1.000000
        valueParm MinusArmOrbitR
            name MinusArmOrbitR
            initValue 0
            hidden 1
            enabled 1
            forceLimits 1
            min 0
            max 2.2
            trackingScale 0.01
            masterSynched 1
            keys
                static  0
                k  0  0
            interpStyleLocked 0
            valueOpDeltaAdd
                Figure 1
                BODY:1
                CTRLArmOrbitR
            strength -1.000000
        valueParm AbsArmOrbitR
            name AbsArmOrbitR
            initValue 0
            hidden 1
            enabled 1
            forceLimits 1
            min 0
            max 2.2
            trackingScale 0.01
            masterSynched 1
            keys
                static  0
                k  0  0
            interpStyleLocked 0
            valueOpDeltaAdd
                Figure 1
                BODY:1
                PlusArmOrbitR
            strength 1.000000
            valueOpDeltaAdd
                Figure 1
                BODY:1
                MinusArmOrbitR
            strength 1.000000
            // Prevent divide by zero error when used as divisor for sign determination
            valueOpKey
                Figure 1
                BODY:1
                CTRLArmOrbitR
            strength 1.000000
                beginValueKeys
                    valueKey -1e-06 0
                    valueKey 0 1
                    valueKey 1e-06 0
                endValueKeys
        valueParm PlusArmOrbitL
            name PlusArmOrbitL
            initValue 0
            hidden 1
            enabled 1
            forceLimits 1
            min 0
            max 2.2
            trackingScale 0.01
            masterSynched 1
            keys
                static  0
                k  0  0
            interpStyleLocked 0
            valueOpDeltaAdd
                Figure 1
                BODY:1
                CTRLArmOrbitL
            strength 1.000000
        valueParm MinusArmOrbitL
            name MinusArmOrbitL
            initValue 0
            hidden 1
            enabled 1
            forceLimits 1
            min 0
            max 2.2
            trackingScale 0.01
            masterSynched 1
            keys
                static  0
                k  0  0
            interpStyleLocked 0
            valueOpDeltaAdd
                Figure 1
                BODY:1
                CTRLArmOrbitL
            strength -1.000000
        valueParm AbsArmOrbitL
            name AbsArmOrbitL
            initValue 0
            hidden 1
            enabled 1
            forceLimits 1
            min 0
            max 2.2
            trackingScale 0.01
            masterSynched 1
            keys
                static  0
                k  0  0
            interpStyleLocked 0
            valueOpDeltaAdd
                Figure 1
                BODY:1
                PlusArmOrbitL
            strength 1.000000
            valueOpDeltaAdd
                Figure 1
                BODY:1
                MinusArmOrbitL
            strength 1.000000
            valueOpKey
                Figure 1
                BODY:1
                CTRLArmOrbitL
            strength 1.000000
                beginValueKeys
                    valueKey -1e-06 0
                    valueKey 0 1
                    valueKey 1e-06 0
                endValueKeys
        valueParm ShrugRatioR
            { // If Orbiting, returns 1 if arms fully up or -1 if arms fully down, else 0
            name ShrugRatioR
            initValue 0
            hidden 1
            enabled 1
            forceLimits 1
            min -2.2
            max 2.2
            trackingScale 0.01
            keys
                static  0
                k  0  0
            interpStyleLocked 0
            // Quotient ranges between +Divisor and -Divisor so output between +1 and -1
            valueOpDeltaAdd
                Figure 1
                BODY:1
            strength 1.000000
            // Divisor protected from ever being exactly zero (1 added when |x| < 1e-6)
            valueOpDivideBy
                Figure 1
                BODY:1
                AbsArmOrbitR
            strength 1.000000
        valueParm ShrugRatioL
            name ShrugRatioL
            initValue 0
            hidden 1
            enabled 1
            forceLimits 1
            min -2.2
            max 2.2
            trackingScale 0.01
            keys
                static  0
                k  0  0
            interpStyleLocked 0
            valueOpDeltaAdd
                Figure 1
                BODY:1
            strength 1.000000
            valueOpDivideBy
                Figure 1
                BODY:1
                AbsArmOrbitL
            strength 1.000000
        valueParm ShrugFactorR
            { // Scale CTRLrShoulderShrug to zero as the arm orbits to the horizontal
            name ShrugFactorR
            initValue 0
            hidden 1
            enabled 1
            forceLimits 1
            min 0
            max 1
            trackingScale 0.01
            keys
                static  0
                k  0  0
            interpStyleLocked 0
            valueOpKey
                Figure 1
                BODY:1
                ShrugRatioR
            strength 1.000000
                beginValueKeys
                    valueKey -1 1
                    valueKey 0 0
                    //valueKey 0 0.5
                    //valueKey 1 0
                endValueKeys
            // Apply full shrug when orbit amplitude is zero (off)
            valueOpKey
                Figure 1
                BODY:1
                CTRLArmOrbitR
            strength 1.000000
                beginValueKeys
                    valueKey -1e-06 0
                    valueKey 0 1
                    valueKey 1e-06 0
                endValueKeys
            // Apply full shrug when CTRLArmsEnableShrug is 1 (on)
            valueOpDeltaAdd
                Figure 1
                BODY:1
                CTRLArmsEnableShrug
            strength 1.000000
        valueParm ShrugFactorL
            { // Scale CTRLlShoulderShrug to zero as the arm orbits to the horizontal
            name ShrugFactorL
            initValue 0
            hidden 1
            enabled 1
            forceLimits 1
            min 0
            max 1
            trackingScale 0.01
            keys
                static  0
                k  0  0
            interpStyleLocked 0
            valueOpKey
                Figure 1
                BODY:1
                ShrugRatioL
            strength 1.000000
                beginValueKeys
                    valueKey -1 1
                    valueKey 0 0
                    //valueKey 0 0.5
                    //valueKey 1 0
                endValueKeys
            valueOpKey
                Figure 1
                BODY:1
                CTRLArmOrbitL
            strength 1.000000
                beginValueKeys
                    valueKey -1e-06 0
                    valueKey 0 1
                    valueKey 1e-06 0
                endValueKeys
            valueOpDeltaAdd
                Figure 1
                BODY:1
                CTRLArmsEnableShrug
            strength 1.000000
My ShareCG Stuff
an0malaus ( ) posted Thu, 27 June 2019 at 12:20 AM · edited Thu, 27 June 2019 at 12:20 AM
Oh, I should note that the file was a work in progress, so none of the ERC linking the BODY master controls to the other actors has been added yet, though the concept has been fully tested.
My ShareCG Stuff
tonyvilters ( ) posted Thu, 27 June 2019 at 5:37 AM
There is also PhilC's Pz3 editor lite that is available here on renderosity. https://www.renderosity.com/mod/freestuff/pz3editor-lite/64262
vholf ( ) posted Thu, 27 June 2019 at 5:15 PM
Thanks for the info!
I have another question for you. What is your workflow for creating such a file? do you code it manually (hope not!) or do you set all the master parameters in poser and then extract it somehow (python?) ?
I would actually pay for a script that would take list of master parameter names and would extract them to a pz2 file to be injected in other figures.
an0malaus posted at 6:13PM Thu, 27 June 2019 - #4354941
unrealblue ( ) posted Fri, 28 June 2019 at 12:10 AM
I'll have to look at that file closer, this weekend.
I'm ready for this part of my "la femme facial expression making" project :)
Couldn't find an easier way to do what I just did... I go out to the last frame, and setup the facial chips into a pose. For symmetric expressions, I can just do one side and mirror.
This script takes those face chip settings (x,y,x rot and trans) at lastframe and wires them into a master (as valueops)
For me, it's a convenient way to make a bunch of master controlled facial expressions using the dizzying array of facial chips.
You give the script a master name. If that master exists, it replaces it. Dangerous. It only wires chip parms that where value@lastframe != initvalue
Seems to work. I made her smile :D
The next step is making each master an injectable "pose" to add it to a La Femme figure.
Then I can post those injectable masters.
unrealblue ( ) posted Fri, 28 June 2019 at 8:13 AM
Well, nuts. I managed to create a file that injects the slaves. And each has the correct actor (BODY) and the correct value. But they're not finding the master parameter. Can a new master not be injected into the body???? This is the code (from the saved CR2 that has the new master. I removed everything else and saved as pz2. For brevity, I removed the slaves since they work. I feel I'm missing something obvious. Writing a file that will inject the slaves is simple enough; the file is not very complex. As an aside, when I use the GUI to add the missing master (that the pz2 didn't add), it's all wired and good to go. And wow, it's beautiful to watch that heap of dependencies work smoothly together to make her smile using a single dial :)
version
    number 11
    build 35540
actor BODY
    channels
        valueParm Smile
            name Smile
            initValue 0
            hidden 0
            enabled 1
            forceLimits 0
            min 0
            max 1
            trackingScale 0.01
            masterSynched 0
            keys
                static  0
                k  0  0
            interpStyleLocked 0
Figure
vholf ( ) posted Fri, 28 June 2019 at 8:21 AM
Is there documentation about this file formats somewhere? or is it all worth of mouth and forums posts? There are lines there I don't know what they do, like trackingScale.
unrealblue ( ) posted Fri, 28 June 2019 at 4:57 PM
Tracking scale, I think is the sensitivity you see in the GUI for settings of a parameter. It's the sensitivity of the "dial". I don't know of any official documentation on any of the file formats. There are people who've written editors that certainly must know more. But I'm not sure if any of them are still involved with Poser and where they got their information from.
I would sure like a wiki of what does what, and (better, maybe) how to do X with Y. I've been using these:
http://docs.daz3d.com/doku.php/artzone/wiki/user/rbtwhiz/technotes/content/erc/start https://www.renderosity.com/mod/forumpro/?thread_id=2735605
And over at SM forums, there's talk of the need to preserve the data in their retiring Poser forums, specifically because there are so many gems in them. I could certainly host a wiki. And I've already probed their API to find that I can dump entire threads as JSON, which is easy to load into any database and present however.
vholf ( ) posted Fri, 28 June 2019 at 6:09 PM
Oh that thread is gold, thank you!
unrealblue ( ) posted Sat, 29 June 2019 at 8:55 AM
You're welcome ^.^
unrealblue ( ) posted Mon, 01 July 2019 at 6:06 PM
Ah, got it. I missed putting in:
createFullBodyMorph Smile
Now I have a nice Master Control "Smile" for La Femme in a pz2 file that can be added to any LF based character.
Okay, now I need modify the Python that combines all the face chips with non-InitValues@lastframe into a single master and have it write that to a pz2. Then I can make expressions all day.
Here is the final working pz2. It makes a master called "Smile" in the BODY, with dependencies in a bunch of facial chips. I think this is the minimal pz2 to accomplish this:
version
    number 11
    build 35540
actor BODY
    channels
        valueParm Smile
            name Smile
            initValue 0
            hidden 0
            enabled 1
            forceLimits 0
            min 0
            max 1
            trackingScale 0.01
            masterSynched 0
            keys
                static  0
                k  0  0
            interpStyleLocked 0
actor uLip
    channels
        rotateX xRotate
            valueOpDeltaAdd
                Figure
                BODY
                Smile
            strength -2.000000
            deltaAddDelta -2.000000
        translateY yTran
            valueOpDeltaAdd
                Figure
                BODY
                Smile
            strength 0.000400
            deltaAddDelta 0.000400
            trackingScaleMult 0.100000
        translateZ zTran
            valueOpDeltaAdd
                Figure
                BODY
                Smile
            strength -0.000400
            deltaAddDelta -0.000400
actor dLip
    channels
        translateZ zTran
            valueOpDeltaAdd
                Figure
                BODY
                Smile
            strength -0.000400
actor rdLip
    channels
        translateY yTran
            valueOpDeltaAdd
                Figure
                BODY
                Smile
            strength 0.000400
actor ldLip
    channels
        translateY yTran
            valueOpDeltaAdd
                Figure
                BODY
                Smile
            strength 0.000400
actor ruLip
    channels
        rotateZ zRotate
            valueOpDeltaAdd
                Figure
                BODY
                Smile
            strength -5.000000
            deltaAddDelta -5.000000
        rotateY yRotate
            valueOpDeltaAdd
                Figure
                BODY
                Smile
            strength 0.027000
            deltaAddDelta 0.027000
        rotateX xRotate
            valueOpDeltaAdd
                Figure
                BODY
                Smile
            strength -0.071900
            deltaAddDelta -0.071900
        translateY yTran
            valueOpDeltaAdd
                Figure
                BODY
                Smile
            strength -0.000200
            deltaAddDelta -0.000200
        translateZ zTran
            valueOpDeltaAdd
                Figure
                BODY
                Smile
            strength -0.000800
            deltaAddDelta -0.000800
actor luLip
    channels
        rotateZ zRotate
            valueOpDeltaAdd
                Figure
                BODY
                Smile
            strength 5.000000
            deltaAddDelta 5.000000
        rotateY yRotate
            valueOpDeltaAdd
                Figure
                BODY
                Smile
            strength -0.027000
            deltaAddDelta -0.027000
        rotateX xRotate
            valueOpDeltaAdd
                Figure
                BODY
                Smile
            strength -0.071900
        translateY yTran
            valueOpDeltaAdd
                Figure
                BODY
                Smile
            strength -0.000200
        translateZ zTran
            valueOpDeltaAdd
                Figure
                BODY
                Smile
            strength -0.000800
actor rLip
    channels
        rotateZ zRotate
            valueOpDeltaAdd
                Figure
                BODY
                Smile
            strength -10.000000
            deltaAddDelta -10.000000
        translateX xTran
            valueOpDeltaAdd
                Figure
                BODY
                Smile
            strength -0.000800
        translateY yTran
            valueOpDeltaAdd
                Figure
                BODY
                Smile
            strength 0.001100
            deltaAddDelta 0.001100
        translateZ zTran
            valueOpDeltaAdd
                Figure
                BODY
                Smile
            strength -0.000400
actor lLip
    channels
        rotateZ zRotate
            valueOpDeltaAdd
                Figure
                BODY
                Smile
            strength 10.000000
            deltaAddDelta 10.000000
        translateX xTran
            valueOpDeltaAdd
                Figure
                BODY
                Smile
            strength 0.000800
            deltaAddDelta 0.000800
        translateY yTran
            valueOpDeltaAdd
                Figure
                BODY
                Smile
            strength 0.001100
        translateZ zTran
            valueOpDeltaAdd
                Figure
                BODY
                Smile
            strength -0.000400
actor nose
    channels
        translateZ zTran
            valueOpDeltaAdd
                Figure
                BODY
                Smile
            strength 0.000100
            deltaAddDelta 0.000100
actor rNostril
    channels
        rotateZ zRotate
            valueOpDeltaAdd
                Figure
                BODY
                Smile
            strength 5.000000
        rotateY yRotate
            valueOpDeltaAdd
                Figure
                BODY
                Smile
            strength -1.000000
actor lNostril
    channels
        rotateZ zRotate
            valueOpDeltaAdd
                Figure
                BODY
                Smile
            strength -5.000000
        rotateY yRotate
            valueOpDeltaAdd
                Figure
                BODY
                Smile
            strength 1.000000
actor luCheek
    channels
        rotateX xRotate
            valueOpDeltaAdd
                Figure
                BODY
                Smile
            strength -5.000000
        translateX xTran
            valueOpDeltaAdd
                Figure
                BODY
                Smile
            strength 0.000800
            trackingScaleMult 1
        translateZ zTran
            valueOpDeltaAdd
                Figure
                BODY
                Smile
            strength -0.000800
actor ruCheek
    channels
        rotateX xRotate
            valueOpDeltaAdd
                Figure
                BODY
                Smile
            strength -5.000000
        translateX xTran
            valueOpDeltaAdd
                Figure
                BODY
                Smile
            strength -0.000800
            trackingScaleMult 1
        translateZ zTran
            valueOpDeltaAdd
                Figure
                BODY
                Smile
            strength -0.000800
actor rdCheek
    channels
        translateX xTran
            valueOpDeltaAdd
                Figure
                BODY
                Smile
            strength -0.000800
            trackingScaleMult 1
        translateY yTran
            valueOpDeltaAdd
                Figure
                BODY
                Smile
            strength 0.000400
        translateZ zTran
            valueOpDeltaAdd
                Figure
                BODY
                Smile
            strength 0.001100
actor ldCheek
    channels
        translateX xTran
            valueOpDeltaAdd
                Figure
                BODY
                Smile
            strength 0.000800
            trackingScaleMult 1
        translateY yTran
            valueOpDeltaAdd
                Figure
                BODY
                Smile
            strength 0.000400
        translateZ zTran
            valueOpDeltaAdd
                Figure
                BODY
                Smile
            strength 0.001100
This should be pretty simple to write to a file from dial settings.
FVerbaas ( ) posted Tue, 02 July 2019 at 12:05 AM
Forum Coordinator
Very useful info, but one suggestion:
At the top of the PoserPython forum there is a notice saying:
I assume this works also for Poser content files.
an0malaus ( ) posted Tue, 02 July 2019 at 1:07 AM
FVerbaas ah, thanks for the tip. Still getting reacquainted with the forum software here and missing the convenience of @username citations and colour-coded, triple-quoted text blocks with a scrolling window.
My ShareCG Stuff
unrealblue ( ) posted Tue, 02 July 2019 at 6:23 AM
an0malaus posted at 9:14PM Tue, 02 July 2019 - #4355789
Oops, Me too. ?
(Had been away from Poser until I read about La Femme a couple of months ago, when cleaning up an old unused email account. Was intrigued. She's fun!)
unrealblue ( ) posted Tue, 02 July 2019 at 6:24 AM
And wow, I didn't realize how long that code post was (sorry) ^///^
vholf ( ) posted Tue, 02 July 2019 at 11:47 AM
Thank you all for the help. I went the other way around while using your code as a reference. I edited the cr2 with all the master parameters and stripped it of everything else, it was faster than manually writing the file for every actor. I was able to create the INJ file and it works.
I'm sure this could be automated with python but I don't currently have the time to get to it. This will do for now. Thanks!
