That has to do with genesis's version o of subdivision. It shouldn't render.
hborre posted at 6:44PM Wed, 18 September 2019 - #4362267
Set sub-d to zero in DSON.
^^^ that.
By default, figure rez is set to "High Definition", and SubD is set to 1 for the G8 figures in DS, if memory serves. Back in DS, crank that back down to "Base Resolution" (which also dumps off the SubD to zero) before you export, and you should be better off.
(no guarantees, but it seems to make the most sense based on what I'm seeing up there.)
Strange line around gENESIS 8 Male, exported DSON, to poser.
outline is appears to follow the actual Morph of the figure but the figure is not snapping to the Morph parameter, weight mapping issue? or something else?
