Mon, Jan 27, 6:25 AM CST
Subject: What's This, What's causing it, and how do I fix it?
Tucan-Tiki ( ) posted Tue, 17 September 2019 at 2:45 AM · edited Mon, 27 January 2025 at 6:22 AM
Strange line around gENESIS 8 Male, exported DSON, to poser.
outline is appears to follow the actual Morph of the figure but the figure is not snapping to the Morph parameter, weight mapping issue? or something else?
Tucan-Tiki ( ) posted Tue, 17 September 2019 at 2:47 AM
poser 11
Boni ( ) posted Tue, 17 September 2019 at 6:44 AM
Check your geometry line settings and comic book settings in the drop down at the bottom of the preview window AND the geometry line settings in the MAT room.
Boni
RedPhantom ( ) posted Tue, 17 September 2019 at 7:18 AM
Site Admin
That has to do with genesis's version o of subdivision. It shouldn't render.
hborre ( ) posted Tue, 17 September 2019 at 7:41 AM · edited Tue, 17 September 2019 at 7:42 AM
Set sub-d to zero in DSON.
quietrob ( ) posted Wed, 18 September 2019 at 6:20 PM
Have you imported Genesis 8 into Poser before?
Penguinisto ( ) posted Wed, 18 September 2019 at 8:47 PM · edited Wed, 18 September 2019 at 8:48 PM
hborre posted at 6:44PM Wed, 18 September 2019 - #4362267
^^^ that.
By default, figure rez is set to "High Definition", and SubD is set to 1 for the G8 figures in DS, if memory serves. Back in DS, crank that back down to "Base Resolution" (which also dumps off the SubD to zero) before you export, and you should be better off.
(no guarantees, but it seems to make the most sense based on what I'm seeing up there.)
