Sun, Jan 26, 10:50 PM CST
Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2025 Jan 26 5:56 am)
banner
Subject: Where did the update put my custom render presets?
Minyassa ( ) posted Sat, 21 September 2019 at 9:30 AM · edited Sun, 26 January 2025 at 1:46 AM
I've done searches on my Poser 11 Content folder and on the Smith Micro folder, can't seem to find them. I did check the "back up my preferences" option during installation.
Rhia474 ( ) posted Sat, 21 September 2019 at 9:38 AM
Hello, mine are here:
Minyassa ( ) posted Sat, 21 September 2019 at 9:51 AM
Thank you, I found the folder you showed me. I don't have that subfolder at all (RenderPresets), I guess it got erased somehow. >_< Oh well, I have a lot of saved scenes I can yank some from, so all is not lost, just a minor PITA.
hborre ( ) posted Sat, 21 September 2019 at 10:23 AM
Next time just select to retain your preferences during install. I haven’t had any problems losing settings on a re-installation
Miss B ( ) posted Sat, 21 September 2019 at 10:48 AM
I chose to retain my preferences, but also just copied the appropriate files from the Roaming folder I wanted to retain. Retaining my preferences did the trick, so I just moved the saved files to my external hard drive, just in case. 😉
_______________
Butterfly Dezignz
Minyassa ( ) posted Sun, 22 September 2019 at 10:35 AM
I did choose to retain my preferences, the program just chose to ignore my choice there. xD I can tell this is going to be a fun relationship already. I guess I should be used to it, I have cats.
samsiahaija ( ) posted Sun, 22 September 2019 at 11:23 PM · edited Sun, 22 September 2019 at 11:32 PM
I just found out Poser 11 and Poser 11 Pro save their presets in differently named folders.
** Poser 11 Pro**: users/(user name)/AppData/Roaming/Poser Pro/11
** Poser 11 Standard:** users/(user name)/AppData/Roaming/Poser/11
You need to manually copy your presets from the old folder to the new one!
Minyassa ( ) posted Mon, 23 September 2019 at 3:31 AM
I actually finally found it, and the problem was a non-standard installation that it did differently this time than the last time. My C drive is for booting up only, all that's supposed to be on there is my OS, so I install to my E drive. I have my Users folder on my E drive as well and last time it used that, but this time it created a new one on my C drive and put my stuff in there. >__< Bad installer, naughty! But at least I found it. Whew. Boy, stuff just really doesn't like you to choose your own installation destinations these days.
Miss B ( ) posted Mon, 23 September 2019 at 12:13 PM
Minyassa posted at 1:12PM Mon, 23 September 2019 - #4363494
I know, and it's gotten so I expect something like this to happen each, and every, time. ~shakes head~
_______________
Butterfly Dezignz
