Thu, Jan 9, 4:43 PM CST
Subject: Resources vanish
drafter69 ( ) posted Tue, 24 September 2019 at 1:32 PM · edited Thu, 09 January 2025 at 4:37 PM
Upgraded and the program works BUT the resources on the right side fail to show up unless I click on the open figure.......... Strange quirk
SamTherapy ( ) posted Tue, 24 September 2019 at 1:39 PM
Crikey, I ain't seen that one. What's yer OS?
quietrob ( ) posted Tue, 24 September 2019 at 1:42 PM
I think your OS AND a screenshot would be helpful. The term "Resources" is rather open-ended.
Afrodite-Ohki ( ) posted Tue, 24 September 2019 at 2:23 PM
Do you mean the entire library? I've noticed that, the first time I load Poser after the updates (in my case updateS because I was an early adopter), the library would load completely white. Just the first time the program opened. I just closed Poser and opened it again and it was solved.
Feel free to call me Ohki!
hborre ( ) posted Tue, 24 September 2019 at 3:25 PM
Online Now!
If we are talking the default setup of the Poser panels, that would make it the Parameter/Preferences panel on the right side of the preview window.
quietrob ( ) posted Tue, 24 September 2019 at 6:23 PM · edited Tue, 24 September 2019 at 6:24 PM
Referencing @4359657
It appears to be a random DS user. He appears to like to drop an egg and then sit back and laugh at those trying to help him.
quietrob ( ) posted Tue, 24 September 2019 at 6:24 PM
drafter69 ( ) posted Wed, 25 September 2019 at 9:11 AM
I love how some people are total assholes.... you seem to fit the bill..... I was referring to the entire library that should appear on the right but in my case is all white.
drafter69 ( ) posted Wed, 25 September 2019 at 9:45 AM
EClark1894 ( ) posted Wed, 25 September 2019 at 11:47 AM · edited Wed, 25 September 2019 at 11:48 AM
drafter69 posted at 12:46PM Wed, 25 September 2019 - #4364047
What happens if you Look under the Windows menu and put a check by Libraries? Looks like you have it undocked AND turned off in the screen shot.
Afrodite-Ohki ( ) posted Wed, 25 September 2019 at 12:24 PM
That's exactly what was happening to me the first time I loaded Poser after a reinstall, but then after I closed the program and loaded it again it fixed the problem. If you've reloaded it after the update, try what EClark said - does that solve the problem?
drafter69 ( ) posted Thu, 26 September 2019 at 10:09 AM
I looked under the windows tab and yes, the show content is checked. Any other ideas????
Afrodite-Ohki ( ) posted Thu, 26 September 2019 at 10:10 AM
Does it work if you set your library to external mode?
EClark1894 ( ) posted Thu, 26 September 2019 at 2:13 PM · edited Thu, 26 September 2019 at 2:14 PM
Is Your Window docked and open?
drafter69 ( ) posted Thu, 26 September 2019 at 2:48 PM
EClark1894 posted at 2:48PM Thu, 26 September 2019 - #4364207
Yes..... I am totally puzzled.
drafter69 ( ) posted Thu, 26 September 2019 at 3:00 PM
I tried something different. When I opened Poser I noticed that the hard drive light was running so I waited almost 8 minutes for it to stop and when it did the resources popped onto the screen. I find it strange that suddenly this seems to be the new normal but I guess I can live with the slowness.
structure ( ) posted Thu, 26 September 2019 at 3:16 PM
Forum Coordinator
I am checking on this
Locked Out
EClark1894 ( ) posted Thu, 26 September 2019 at 4:49 PM · edited Thu, 26 September 2019 at 4:50 PM
drafter69 posted at 5:47PM Thu, 26 September 2019 - #4364220
That was actually what I was going to suggest next, as mine does that everytime I boot up. Still, 8 minutes is a little excessive. The longest I ever waited I think was 30 seconds to a minute. And that was before the update.
raven ( ) posted Fri, 27 September 2019 at 7:19 AM
A couple of options.
Do you have 'Refresh on Launch' checked in the Library tab of your General Preferences? Maybe that's the cause.
Or in the library options, is 'Reopen Folders' checked? That may cause a slowdown too.
EClark1894 ( ) posted Fri, 27 September 2019 at 7:30 AM
You might also check your User Preferences and see if your Library Search options are set on Deep or Shallow. Set it to Shallow.
drafter69 ( ) posted Sat, 28 September 2019 at 9:30 AM
EClark1894 posted at 9:29AM Sat, 28 September 2019 - #4364332
BINGO...... that did it. The setting was to DEEP.
The instant I changed it the resources appeared.
Thank you so very much.....
I hope others check to be sure they do not have the same problem setting
randym77 ( ) posted Sat, 28 September 2019 at 10:56 PM
Interesting. Mine was set to deep, too. I don't think I ever changed it, so maybe that's the default?
Didn't take much time to load up, but I have a lot of fairly small runtimes, rather than a few big ones, so maybe that makes a difference?
EClark1894 ( ) posted Sun, 29 September 2019 at 3:43 PM
I think DEEP is the default. I prefer to put it on Shallow or NONE.
