Crikey, I ain't seen that one. What's yer OS?
Do you mean the entire library? I've noticed that, the first time I load Poser after the updates (in my case updateS because I was an early adopter), the library would load completely white. Just the first time the program opened. I just closed Poser and opened it again and it was solved.
Feel free to call me Ohki!
It appears to be a random DS user. He appears to like to drop an egg and then sit back and laugh at those trying to help him.
I love how some people are total assholes.... you seem to fit the bill..... I was referring to the entire library that should appear on the right but in my case is all white.
That's exactly what was happening to me the first time I loaded Poser after a reinstall, but then after I closed the program and loaded it again it fixed the problem. If you've reloaded it after the update, try what EClark said - does that solve the problem?
EClark1894 posted at 2:48PM Thu, 26 September 2019 - #4364207
Is Your Window docked and open?
Yes..... I am totally puzzled.
I tried something different. When I opened Poser I noticed that the hard drive light was running so I waited almost 8 minutes for it to stop and when it did the resources popped onto the screen. I find it strange that suddenly this seems to be the new normal but I guess I can live with the slowness.
drafter69 posted at 5:47PM Thu, 26 September 2019 - #4364220
That was actually what I was going to suggest next, as mine does that everytime I boot up. Still, 8 minutes is a little excessive. The longest I ever waited I think was 30 seconds to a minute. And that was before the update.
EClark1894 posted at 9:29AM Sat, 28 September 2019 - #4364332
You might also check your User Preferences and see if your Library Search options are set on Deep or Shallow. Set it to Shallow.
BINGO...... that did it. The setting was to DEEP.
The instant I changed it the resources appeared.
Thank you so very much.....
I hope others check to be sure they do not have the same problem setting
Upgraded and the program works BUT the resources on the right side fail to show up unless I click on the open figure.......... Strange quirk
