Tue, Jan 21, 10:30 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 11:41 am)
Subject: Injection Morph for Project Evolution to Fit Other Figures Hair to Head?
Anim8dtoon ( ) posted Fri, 27 September 2019 at 2:28 PM · edited Mon, 06 January 2025 at 3:01 PM
Forum Moderator
Hi peeps! Do any of you know if there's an injection morph out there for PE to enable her to use other figures' hair? I have a TON of V4 hair I would like to use with her, but don't want to be spending hours doing the manual fittings. Thanks in advance!
Boni ( ) posted Fri, 27 September 2019 at 2:35 PM
Wow, good question ... I would use that as well!!
Boni
Anim8dtoon ( ) posted Fri, 27 September 2019 at 2:49 PM
Forum Moderator
Boni posted at 2:48PM Fri, 27 September 2019 - #4364434
Wow, good question ... I would use that as well!! Thank you, Boni! Maybe Erogenesis himself would be willing to create the injection morph. I know that Blackhearted did one for La Femme so she could use V4 hair.
Anim8dtoon ( ) posted Fri, 27 September 2019 at 3:03 PM
Forum Moderator
I just sent a site mail to Erogenesis asking him if he'd be willing to create the injection morph for PE. Keeping my fingers crossed!
hborre ( ) posted Fri, 27 September 2019 at 3:51 PM
The only application out right now that can fit V4 hair to PE is Fverbaas Prefitter-CR2 found here: . You will need to also purchase Project Evolution injection for Prefitter-CR2, add-on for it to work properly. Easy to use and convenient.
RobZhena ( ) posted Fri, 27 September 2019 at 4:26 PM
Parent the hair. I do it all the time.
randym77 ( ) posted Fri, 27 September 2019 at 4:58 PM
Hair is relatively easy to use on other figures, but there are some styles that are tricky. Styles where the hairline shows can be difficult to get right. Especially at the temples.
RobZhena ( ) posted Fri, 27 September 2019 at 6:21 PM
Scaling is your friend.
randym77 ( ) posted Fri, 27 September 2019 at 11:42 PM
Scaling only does so much. If the head shape is different, scaling doesn't work that well for, say, short hair at the sides.
You can use magnets to adjust the fit, but a morph like La Femme has would be so much easier.
RobZhena ( ) posted Sat, 28 September 2019 at 5:08 AM
Looking at it, I don't see how a morph would do the trick because the V4 hair conforms so low on PE's head. If you get the beta mannequins at the other site that carries PE, it includes a hair mannequin. Now that everybody has the fitting and setup rooms, you can scale the hair mannequin and rig the V4 hair to PE. Then, copy the morphs from the V4 hair. That won't work for every style because the mannequin doesn't include, for example, bangs, but if the V4 hair you are converting is from DAZ, it almost certainly will have movement morphs for that style of hair that should transfer fine. No solution is likely to be perfect.
FVerbaas ( ) posted Sat, 28 September 2019 at 5:16 AM
Forum Coordinator
Yes the Prefitter-CR2 is one way to go. Thank you for mentioning,
There is also a content development kit for PE. It is available on CGBytes and it has an injection morph for V4 to correct the shape to PE and mannequins you can use as source for joint copy and morph copy. It is still in Beta and officially for the Early Edition of PE, but it works fine for the One and OneX versions. Personally I use a combination of the Prefitter for geometry transform and the mannequins as donor for rig and PE morphs.
