Looking at it, I don't see how a morph would do the trick because the V4 hair conforms so low on PE's head. If you get the beta mannequins at the other site that carries PE, it includes a hair mannequin. Now that everybody has the fitting and setup rooms, you can scale the hair mannequin and rig the V4 hair to PE. Then, copy the morphs from the V4 hair. That won't work for every style because the mannequin doesn't include, for example, bangs, but if the V4 hair you are converting is from DAZ, it almost certainly will have movement morphs for that style of hair that should transfer fine. No solution is likely to be perfect.
Yes the Prefitter-CR2 is one way to go. Thank you for mentioning,
There is also a content development kit for PE. It is available on CGBytes and it has an injection morph for V4 to correct the shape to PE and mannequins you can use as source for joint copy and morph copy. It is still in Beta and officially for the Early Edition of PE, but it works fine for the One and OneX versions. Personally I use a combination of the Prefitter for geometry transform and the mannequins as donor for rig and PE morphs.
Hi peeps! Do any of you know if there's an injection morph out there for PE to enable her to use other figures' hair? I have a TON of V4 hair I would like to use with her, but don't want to be spending hours doing the manual fittings. Thanks in advance!
