Mon, Jan 6, 8:50 PM CST
Subject: Does the 11.2 update work for Poser 11 Pro?
Darkworld ( ) posted Fri, 11 October 2019 at 11:10 AM · edited Sun, 05 January 2025 at 2:22 AM
The only version I saw mentioned was GameDev, which I do not have. I have been using Poser 11 Pro since it came out, which is quite different from poser 11.
Yet my version just crapped out telling me it can no longer be activated... so will the 11.2 update fix Poser 11 PRO?
Thanks!
Darkworld ( ) posted Fri, 11 October 2019 at 11:13 AM · edited Fri, 11 October 2019 at 11:14 AM
In trying to install it looks like it wants me to install a FULL version of Poser 11.2.
But isn't 11.2 just an update? I'd like to update Poser 11 Pro to get it working again (I'm not understanding why the activation suddenly died).
wheatpenny ( ) posted Fri, 11 October 2019 at 11:14 AM
Site Admin
Yes, the new upgrade works with 2014 Game Dev, Poser 11, and Poser 11 pro.
Jeff
Renderosity Senior Moderator
Hablo español
Ich spreche Deutsch
Je parle français
Mi parolas Esperanton. Ĉu vi?
wheatpenny ( ) posted Fri, 11 October 2019 at 11:15 AM
Site Admin
The reason the activation suddenly stopped working is because SmithMicro took the server offline, since they no longer own Poser.
Jeff
Hablo español
Ich spreche Deutsch
Je parle français
hborre ( ) posted Fri, 11 October 2019 at 11:18 AM
The newer software will completely uninstall your old version and replace it with the current version and build. Don't forget the support.exe and extra new content. You will need your sn to access both new and legacy content.
saibabameuk ( ) posted Fri, 11 October 2019 at 11:19 AM
Just laughing about Poser 11 Pro, I had such a bad time making it work that I went back to my Poser Pro 12. So its good you raised this topic. It forced me to ditch Pro11 ( Bin ) and try downloading a new Install. Ironic if this works.
Darkworld ( ) posted Fri, 11 October 2019 at 11:22 AM
I love Pro, animating for games the vanilla poser 11 is useless for me. OK I will install the new one but I use external runtimes and I'm leery of this screwing that up lol.
Here goes!
Glitterati3D ( ) posted Fri, 11 October 2019 at 11:38 AM
Darkworld posted at 12:36PM Fri, 11 October 2019 - #4366772
Here goes!
REMEMBER to use existing settings when installing and it will leave all your runtimes where they belong. The prompt for this comes at the tail end of the installation process, so pay close attention.
quietrob ( ) posted Fri, 11 October 2019 at 11:40 AM
saibabameuk posted at 9:39AM Fri, 11 October 2019 - #4366769
Poser Pro 12 is just a nickname, right?
saibabameuk ( ) posted Fri, 11 October 2019 at 12:19 PM
hborre ( ) posted Fri, 11 October 2019 at 12:34 PM
Poser Pro 2012 is the correct terminology for this version.
EClark1894 ( ) posted Fri, 11 October 2019 at 1:09 PM
2012 is the year it came out, not the version. That would be version Poser Pro 9 (2012).
structure ( ) posted Fri, 11 October 2019 at 1:18 PM
Forum Coordinator
It was actually called Poser Pro 2012, as pp14 was called poser pro 2014, the 9 and 10 referred to the standard versions, not the pro.
Locked Out
quietrob ( ) posted Fri, 11 October 2019 at 1:48 PM · edited Fri, 11 October 2019 at 1:55 PM
saibabameuk posted at 11:47AM Fri, 11 October 2019 - #4366788
Err if you say so right?....
I know...saying it's Poser 12 is correct...from a certain point of view. Nice try Obi-wan. Try taking the high ground.
saibabameuk ( ) posted Fri, 11 October 2019 at 1:56 PM
I am to old for all this, I just wanted to do a little animation movie. https://youtu.be/8rS_rgK_UzU -----had to use Poser Pro 12 becouse I could not make Poser Pro 11 work . I have dowloaded the update and guess what my PNG is still giving me problems. Test1.0001.png Andy is supposed to have just a shadow not the rest of the back ground? Ground has Shadow catch only in material room. FireFly render image file. Any ideas or should this be a new topic. Test4.0001.png
A_Sunbeam ( ) posted Fri, 11 October 2019 at 2:04 PM
I've just downloaded and installed 11.2.307 and it runs well on my MacBook (OS El Capitan). The recent render window is now fixed. Also works on Mojave.
saibabameuk ( ) posted Fri, 11 October 2019 at 2:04 PM
Got it Shadow catch only for Background Ticked and got my PNG working for the next animation. Thanks guys.Test5.0001.png
saibabameuk ( ) posted Fri, 11 October 2019 at 2:08 PM
A_Sunbeam posted at 8:05PM Fri, 11 October 2019 - #4366805
I've just downloaded and installed 11.2.307 and it runs well on my MacBook (OS El Capitan). The recent render window is now fixed. Also works on Mojave. Pleased about that will download and try soon.
quietrob ( ) posted Fri, 11 October 2019 at 2:26 PM
saibabameuk posted at 12:24PM Fri, 11 October 2019 - #4366804
I am to old for all this,.... Any ideas or should this be a new topic.
I think a new thread would be helpful. We have a few animators here. Plus it wouldn't be buried in an update thread.
Good Luck.
Afrodite-Ohki ( ) posted Fri, 11 October 2019 at 2:47 PM
The reason why people are correcting you on Poser Pro 2012 is because, supposedly, the next Poser version will be Poser 12, likely not even being made yet, however Poser Pro 2012 was two versions ago. They're just trying to avoid confusion.
Basically we had (if I remember correctly and not counting spin-off versions like Debut and Game Dev):
Poser 1 ~ 7 Poser 8 / Poser Pro Poser 9 / Poser Pro 2012 Poser 10 / Poser Pro 2014 Poser 11 / Poser Pro 11
Which is super confusing because Poser has changed owner several times and they weren't consistent with their naming. But everything now points to that the future one will be just Poser 12, as Bondware has turned both Poser 11 and Poser Pro 11 into just Poser 11.2 - it doesn't look like they'll be making two separate programs for the same version.
Feel free to call me Ohki!
Afrodite-Ohki ( ) posted Fri, 11 October 2019 at 4:22 PM
Ugh I forgot the bug where single linespaces become one line of text. Here:
Poser 1 ~ 7
Poser 8 / Poser Pro
quietrob ( ) posted Fri, 11 October 2019 at 6:35 PM
Thanks Ohki and all. Except for what his face passive aggressive, I knew you would come through with a real answer.
ratscloset ( ) posted Sat, 12 October 2019 at 12:27 AM
The versions are
Poser 1 - 4 Poser Pro Pack for Poser 4 Poser 5 - 6 Poser 7/Poser Pro Base/Poser Pro/Poser Figure Artist Poser 8/Poser Pro 2010/Poser Debut Poser 9/Poser Pro 2012 Poser 10/Poser Pro 2014/Poser Pro 2014 Game Dev/Poser Debut Update Poser 11/Poser Pro 11 Poser 11.2 which contains all the Poser Application features previously limited to Poser Pro 11 (Export, GPU Rendering, Fitting Room, etc...)
So, if you have Poser Pro 11, Poser 11, or Poser Pro 2014 Game Dev, you want the Poser 11.2 and it is free
There are attractive Upgrade Offers for Poser Debut, Poser 6 - 10, and Poser Pro 2010 - Poser Pro 2014 (Only Poser Pro 2010 - Poser Pro 2012 are listed, but I checked and Poser Pro 2014 (non Game Dev key does work for the Upgrade Purchase. Did not have a Poser Pro or Poser Pro Base key to check if they also work.
ratscloset
aka John
westcat ( ) posted Thu, 28 November 2019 at 9:52 AM
My Poser 11 stopped working??? It is NOT a demo I PAID for it !!!!!!!!!!!!!!
Where is Poser 11.2 please
thank you
Nails60 ( ) posted Thu, 28 November 2019 at 10:22 AM
Here
https://www.posersoftware.com/downloads
Afrodite-Ohki ( ) posted Thu, 28 November 2019 at 10:24 AM
westcat posted at 1:24PM Thu, 28 November 2019 - #4371558
thank you
Afrodite-Ohki ( ) posted Thu, 28 November 2019 at 10:25 AM
Damn, Nails60 beat me to it 😂
