Forum Moderators: RedPhantom
Darkworld posted at 12:36PM Fri, 11 October 2019 - #4366772
I love Pro, animating for games the vanilla poser 11 is useless for me. OK I will install the new one but I use external runtimes and I'm leery of this screwing that up lol.
Here goes!
REMEMBER to use existing settings when installing and it will leave all your runtimes where they belong. The prompt for this comes at the tail end of the installation process, so pay close attention.
saibabameuk posted at 9:39AM Fri, 11 October 2019 - #4366769
Just laughing about Poser 11 Pro, I had such a bad time making it work that I went back to my Poser Pro 12. So its good you raised this topic. It forced me to ditch Pro11 ( Bin ) and try downloading a new Install. Ironic if this works.
Poser Pro 12 is just a nickname, right?
saibabameuk posted at 11:47AM Fri, 11 October 2019 - #4366788
Err if you say so right?....
I know...saying it's Poser 12 is correct...from a certain point of view. Nice try Obi-wan. Try taking the high ground.
I am to old for all this, I just wanted to do a little animation movie. https://youtu.be/8rS_rgK_UzU -----had to use Poser Pro 12 becouse I could not make Poser Pro 11 work . I have dowloaded the update and guess what my PNG is still giving me problems. Andy is supposed to have just a shadow not the rest of the back ground? Ground has Shadow catch only in material room. FireFly render image file. Any ideas or should this be a new topic.
saibabameuk posted at 12:24PM Fri, 11 October 2019 - #4366804
I am to old for all this,.... Any ideas or should this be a new topic.
I think a new thread would be helpful. We have a few animators here. Plus it wouldn't be buried in an update thread.
Good Luck.
The reason why people are correcting you on Poser Pro 2012 is because, supposedly, the next Poser version will be Poser 12, likely not even being made yet, however Poser Pro 2012 was two versions ago. They're just trying to avoid confusion.
Basically we had (if I remember correctly and not counting spin-off versions like Debut and Game Dev):
Poser 1 ~ 7 Poser 8 / Poser Pro Poser 9 / Poser Pro 2012 Poser 10 / Poser Pro 2014 Poser 11 / Poser Pro 11
Which is super confusing because Poser has changed owner several times and they weren't consistent with their naming. But everything now points to that the future one will be just Poser 12, as Bondware has turned both Poser 11 and Poser Pro 11 into just Poser 11.2 - it doesn't look like they'll be making two separate programs for the same version.
Feel free to call me Ohki!
Ugh I forgot the bug where single linespaces become one line of text. Here:
Poser 1 ~ 7
Poser 8 / Poser Pro
The versions are
Poser 1 - 4 Poser Pro Pack for Poser 4 Poser 5 - 6 Poser 7/Poser Pro Base/Poser Pro/Poser Figure Artist Poser 8/Poser Pro 2010/Poser Debut Poser 9/Poser Pro 2012 Poser 10/Poser Pro 2014/Poser Pro 2014 Game Dev/Poser Debut Update Poser 11/Poser Pro 11 Poser 11.2 which contains all the Poser Application features previously limited to Poser Pro 11 (Export, GPU Rendering, Fitting Room, etc...)
So, if you have Poser Pro 11, Poser 11, or Poser Pro 2014 Game Dev, you want the Poser 11.2 and it is free
There are attractive Upgrade Offers for Poser Debut, Poser 6 - 10, and Poser Pro 2010 - Poser Pro 2014 (Only Poser Pro 2010 - Poser Pro 2012 are listed, but I checked and Poser Pro 2014 (non Game Dev key does work for the Upgrade Purchase. Did not have a Poser Pro or Poser Pro Base key to check if they also work.
ratscloset
aka John
westcat posted at 1:24PM Thu, 28 November 2019 - #4371558
My Poser 11 stopped working??? It is NOT a demo I PAID for it !!!!!!!!!!!!!!
Where is Poser 11.2 please
thank you
https://www.posersoftware.com/downloads
The only version I saw mentioned was GameDev, which I do not have. I have been using Poser 11 Pro since it came out, which is quite different from poser 11.
Yet my version just crapped out telling me it can no longer be activated... so will the 11.2 update fix Poser 11 PRO?
Thanks!
