Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 09 4:36 am)
Yes, I did work with the collar, but I wasn't able to get the arm into position. (I was, however, able to completely mangle it--even with limits set to on). I haven't tried this with any other P4 figures, but this seems to me to be a real problem. The human arm can position the hand in just about any orientation in an entire octant of space, apparently Poser does not have that capability. Thanks for the suggestion. Cal
Attached Link: http://yarchive.net/space/spacecraft/gimbal_lock.html
My guess is that it has to do with the way/order that the joint rotations are applied. I've seen this before in 3D Studio MAX. (The phenomena is similar to a "gimble lock" that mechanisms such as gyroscopes can experience.) It might be possible to fix it if the base orientations of the joints can be changed. I just don't have the time or energy to dig into it right now. Looks as if I'm going to have to scrap Poser for this project and dust off my trusty old copy of Humanoid. Calheyas; when i get gimbal lock, usually i try grabbing the arm part (ie the shoulder, here) and draggin the rotation tool across to move it. click on the shoulder to select it, then hold down the shift key, and drag the rotate tool sideways in the window. this might move the arm where you want it. the other solution would be to re-zero the collar and/or shoulder and start again. :/ it doesnt sound like fun, but it can be quicker than trying to force the arm around while it is gimbal locked.
I re-zeroed both collar and shoulder many times, there was just no getting to the desired postion. Changing the joint order to YXZ seems to eliminate the gimble lock. However, when I made the change, I got a warning that I might need to "readjust joint zones", and the upper arm is obviously not blending correctly. I was hoping someone had tried the joint zone thing and could give me some idea if it was worth a shot. Any ideas? Cal
