Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 7:34 am)
Oh, I already have it up and running. Had to do a bit of an arse backwards way of getting my prefs back, though. I loaded a scene that used most of my default settings - I do a lot of test renders - and deleted the figures, repositioned the camera, then saved preferred scene, so at least I have that back.
Now I have to find where Snarly's EZSkin prefs are at, since the new install kindly trashed all of those.
Thanks for the heads up on finding the renders, though. I'll hunt the buggers down now. A-hunting we will go...
hborre posted at 7:05PM Wed, 11 December 2019 - #4373023
Whenever you update from a previous install, make sure that you select the option to retain your custom preferences.
I'll make sure I remember in future. Oh well, got me renders back and most of me prefs.
Tell you what, though... Poser seems a heck of a lot slower now. Opening folders in the Libraries takes forever, as does refresh when you add anything. Render seems to be acting a bit weird, too; I converted a hair using EZSkin's hair shader and for some bizarre reason, SSS ain't picking it up. Never happened before.
Snarlygribbly posted at 7:08PM Wed, 11 December 2019 - #4373026
C:Users>[name]>AppData>Roaming>Poser Pro>11>ezskin3
Aye, lad. Found 'em, ta.
You can backup your preferred state - and then use this script ( read the instructions ) to bring it back should you accidentally overwrite your current one.
Locked Out
A_Sunbeam posted at 1:53PM Fri, 13 December 2019 - #4373199
hborre posted at 11:34AM Fri, 13 December 2019 - #4373023
For some odd reason the panel never offers me that option! (iMac)
I think I'll remember in future. Maybe.
A_Sunbeam posted at 8:18PM Sat, 14 December 2019 - #4373199
Yeah, I think thats a PC only thing. What I've been doing is making a duplicate Poser, saving the prior version elsewhere, and letting the update do its thing on the copy in the Applications menu.
I got the new Rendo version when it was launched, set it up how I wanted and carried on. Yesterday, I decided to update it, since there's a newer version which apparently cures the "random delete of previously saved renders and/or randomly replace previously deleted renders" bug.
Any road up, without thinking, I let the bugger remove me previous version and reinstall. Now I've lost all me settings and a bunch of renders I hadn't saved out. Anyone know where I can find 'em, or have I completely bollocksed it?
