Mon, Jan 20, 10:42 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 7:34 am)
Subject: Oopsie. Installed latest update for Poser
SamTherapy ( ) posted Wed, 11 December 2019 at 11:14 AM · edited Sun, 05 January 2025 at 6:26 AM
I got the new Rendo version when it was launched, set it up how I wanted and carried on. Yesterday, I decided to update it, since there's a newer version which apparently cures the "random delete of previously saved renders and/or randomly replace previously deleted renders" bug.
Any road up, without thinking, I let the bugger remove me previous version and reinstall. Now I've lost all me settings and a bunch of renders I hadn't saved out. Anyone know where I can find 'em, or have I completely bollocksed it?
quietrob ( ) posted Wed, 11 December 2019 at 11:33 AM · edited Wed, 11 December 2019 at 11:36 AM
They are saved under C:Users>name>AppData>Roaming>Poser Pro>11>RenderCache
You can at least copy the files to a secure location to make certain they don't get wiped out. Then when you get your Poser up and running again....you should be able to put them back.
SamTherapy ( ) posted Wed, 11 December 2019 at 12:03 PM
Oh, I already have it up and running. Had to do a bit of an arse backwards way of getting my prefs back, though. I loaded a scene that used most of my default settings - I do a lot of test renders - and deleted the figures, repositioned the camera, then saved preferred scene, so at least I have that back.
Now I have to find where Snarly's EZSkin prefs are at, since the new install kindly trashed all of those.
Thanks for the heads up on finding the renders, though. I'll hunt the buggers down now. A-hunting we will go...
hborre ( ) posted Wed, 11 December 2019 at 12:24 PM
Whenever you update from a previous install, make sure that you select the option to retain your custom preferences.
Snarlygribbly ( ) posted Wed, 11 December 2019 at 1:07 PM · edited Wed, 11 December 2019 at 1:07 PM
C:Users>[name]>AppData>Roaming>Poser Pro>11>ezskin3
Free stuff @ https://poser.cobrablade.net/
SamTherapy ( ) posted Wed, 11 December 2019 at 1:08 PM
hborre posted at 7:05PM Wed, 11 December 2019 - #4373023
I'll make sure I remember in future. 😀 Oh well, got me renders back and most of me prefs.
Tell you what, though... Poser seems a heck of a lot slower now. Opening folders in the Libraries takes forever, as does refresh when you add anything. Render seems to be acting a bit weird, too; I converted a hair using EZSkin's hair shader and for some bizarre reason, SSS ain't picking it up. Never happened before.
Snarlygribbly posted at 7:08PM Wed, 11 December 2019 - #4373026
Aye, lad. Found 'em, ta.
structure ( ) posted Thu, 12 December 2019 at 10:07 PM
Forum Coordinator
You can backup your preferred state - and then use this script ( read the instructions ) to bring it back should you accidentally overwrite your current one.
Locked Out
SamTherapy ( ) posted Fri, 13 December 2019 at 4:58 AM
Thanks!
A_Sunbeam ( ) posted Fri, 13 December 2019 at 5:35 AM
hborre posted at 11:34AM Fri, 13 December 2019 - #4373023
For some odd reason the panel never offers me that option! (iMac)
SamTherapy ( ) posted Fri, 13 December 2019 at 7:54 AM
A_Sunbeam posted at 1:53PM Fri, 13 December 2019 - #4373199
I think I'll remember in future. Maybe. 😁
SeanMartin ( ) posted Sat, 14 December 2019 at 7:19 PM
A_Sunbeam posted at 8:18PM Sat, 14 December 2019 - #4373199
Yeah, I think thats a PC only thing. What I've been doing is making a duplicate Poser, saving the prior version elsewhere, and letting the update do its thing on the copy in the Applications menu.
