Fri, Jan 3, 1:59 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 02 11:49 pm)
Subject: How do I turn off Blue Reflections on model?
CHMedia ( ) posted Wed, 26 February 2020 at 2:23 PM · edited Fri, 03 January 2025 at 1:56 AM
I tried to render my latest gallery image in Superfly but used firefly instead because of all that blue.
I really like the reflections in the window but how do I turn it off on the model?
How do I make it look less grainy?
structure ( ) posted Wed, 26 February 2020 at 3:33 PM · edited Wed, 26 February 2020 at 3:35 PM
Forum Coordinator
I am not sure this is the answer but that looks like your lights are too bright.
also if those are firefly materials, you will possibly need to edit them.
As for the grainy, there a couple of denoisers out there. Generally speaking the higher the render settings, the less grain there is.
Locked Out
hborre ( ) posted Wed, 26 February 2020 at 8:28 PM
That definitely looks like specular bloom associated with lighting conditions. However, I don't see it everywhere on the model, the pants and the black top are not showing any signs of blooming. You can get this effect when Gamma Correction is incorrectly set to 1 or turned off entirely. It would be interesting to see the render, material, and lighting settings to try to implement corrective suggestions.
bantha ( ) posted Thu, 27 February 2020 at 8:27 AM
It lookl like too much lights with an unsuitable shader. Could you please show us the material, with the node view?
-"Amazing Grace" Hopper
CHMedia ( ) posted Fri, 28 February 2020 at 9:39 AM
CHMedia ( ) posted Fri, 28 February 2020 at 11:20 AM
I've only ever done nodes in blender...
This is the default after selecting La Femme's body. Should I sample from another part of the image?
ironsoul ( ) posted Fri, 28 February 2020 at 1:28 PM
I'm not familar with the spec/gloss method but for everyday materials like wood/cloth/metal the roughness/metal approach will work well since you only set the roughness and the physicalsurface node will do all the math for you. My suggestion would be to unplug the Gloss/Sepcular convertor from both parameters and drive the highlights via the roughness value.
structure ( ) posted Fri, 28 February 2020 at 2:27 PM · edited Fri, 28 February 2020 at 2:28 PM
Forum Coordinator
turn off branched path tracing for superfly
Locked Out
ghostship2 ( ) posted Fri, 28 February 2020 at 3:59 PM
structure posted at 2:57PM Fri, 28 February 2020 - #4382060
I would agree that this is the problem. It looks like fireflys caused by clamp set to 0 which is the case when you turn BPT on.
