Forum Moderators: Lobo3433
3D Modeling F.A.Q (Last Updated: 2024 Dec 01 9:00 pm)
Blender | Trimble Sketchup | Wings 3D | Anim8or | Metasequoia | Clara IO (Browser-based 3d modeler)
Check out the MarketPlace Wishing Well, as a content creator's resource for your next project.
Rhino is a good modeler. It is used alot in making props for Poser, from what I've heard. In Rhino, you just import what you want to work on (i.e., Poser character). Ask for the specifics in the Poser or Rhino forum. What matters is that you practice modeling and learn the fundamentals of it. It's not up to what software you use--as long as it's decent--you should be able to model anything you want. Just because someone has Lightwave or Maya doesn't mean they'll automatically be better at modeling. You want to model, so use Rhino and learn to model. They have plenty of tutorials in the Rhino forum. Stop sitting on your hands and go check them out.
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12371
As Co-Moderator of the Rhino Forum, I have to say that CloudedInMystery is right. We even have a Rhino to Poser ProPack tutorial available at the forum. Drop by and ask us anything. You won't be left waiting very long and you'll almost always get the fastest solution to your problem.More realistic models? I doubt that. How much realism you get from a model is soley up to your skill. Now, if you want to use textures in Rhino, may I suggest getting Bryce because you won't be able to do it very well right now. Rhino is a modeler and isn't pretending to be more than that. There are a few rendering programs that work with Rhino but you'd be better off with an entirely seperate program for rendering with textures. Bryce is a low cost landscape tool that offers great (if slow) rendering. Now if you were to say you could get more realistic textures and special effects in Max, you'd be right. That's Max's major goal as a "full 3D package"...final images. Rhino on the other hand provides you with a fast, easy to learn, powerful modeling alternative that works well with other programs (like Max).
You can do as Teyon said. Also, you could get UVMapper (free) which will enable you to make UV templates for your models. Then you can import that template into your paint program and create your texture and bump maps (as well as any other your program supports). If you just want to model, stick to a modeling program. Lightwave, Maya, and Max are much more than modeling programs.
I am just trying to get into modeling. I have rhino just haven't used it as much. Should I stick with rhino or try a different program. Second How can I take something from poser like a prop or person and add stuff to it. Like wings, a extra arm are something.
