Fri, Jan 10, 8:55 PM CST
Renderosity Forums / Freestuff
Welcome to the Freestuff Forum
Forum Moderators: wheatpenny, RedPhantom Forum Coordinators: Anim8dtoon
Freestuff F.A.Q (Last Updated: 2025 Jan 07 1:52 pm)
Welcome to the Freestuff Forum. The Freestuff Forum is intended for all  freestuff related postings within our community. This is a highlight area where our membership is invited to review, announce and give feedback in greater detail on various freestuff items offered.  Members can also post wishes of freestuff items they would like to see.
Notice: Links to offsite 'For Sale' items will be removed
Renderosity Free Stuff Area
Free Stuff Gallery
Free Stuff Guidelines
Subject: License question
anniemation ( ) posted Sun, 12 April 2020 at 6:24 PM · edited Fri, 10 January 2025 at 6:29 PM
I'm making a freebie and wondered if the license of this can be used on it. I messaged the creator but it looks like they haven't been around much.
https://www.renderosity.com/mod/freestuff/tabalas-p6-metals/32662
hborre ( ) posted Sun, 12 April 2020 at 7:23 PM
Online Now!
There is usually a readme file in some of those freebies, you could check if one exists. It might be all right as long as it's not the collection, just used to procedurally texture an object. I am familiar with the set, however, those textures are quite dated with better ways to make them more realistic in response to their enviroment.
anniemation ( ) posted Sun, 12 April 2020 at 9:13 PM
Hmm can you point me in the direction I should go to do the textures better?
hborre ( ) posted Sun, 12 April 2020 at 9:26 PM · edited Sun, 12 April 2020 at 9:26 PM
Online Now!
Which Poser version are you using and, if it's Poser 11, Firefly or Superfly? I am assuming Firefly. And what type of texture are you attempting?
anniemation ( ) posted Sun, 12 April 2020 at 9:29 PM
I'm more of a SF user but I'd like create materials for both. Poser 11.romanj.jpg
hborre ( ) posted Sun, 12 April 2020 at 10:34 PM
Online Now!
Same here. I am currently looking at the Tabala textures and running a few renders in both render engines. I am also modifying and testing a few of the metallic textures using the PBR node which works nicely with both engines. I suggest that you go into the Material Catalogue of the Poser 11 Content Library and look under Superfly>Afrodite-Ohki; she has several free textures covering different materials. They work for both engines. In the image you included, is that the effect of the material you want? Which Tabala texture is that?
anniemation ( ) posted Sun, 12 April 2020 at 10:50 PM
That's one of the irons.
anniemation ( ) posted Sun, 12 April 2020 at 10:53 PM
Apparently the ancient helmets were bronze or copper but I couldn't find a decent shader for either of those.
Miss B ( ) posted Sun, 12 April 2020 at 11:29 PM
I have Dimension3D's SuperFly Materials, and there a bunch of Metal you might like.
Dimension 3D's SuperFly Mats
_______________
Butterfly Dezignz
hborre ( ) posted Sun, 12 April 2020 at 11:40 PM
Online Now!
If I use procedural shaders for texturing, I usually look for something close and modify it until I get a render I like. But I also like the material to behave physically correct or it will just look wrong. Here is an image, rendered in Superfly, combining a bronze procedural with Tabala's iron texture arrangement. I like to render with a dome (Snarlygribbly's EZDome) to check how the shader responds to ambient light.
I re-rendered the same scene but moved the light for a better representation. Done in Firefly. I do not like the results which mean I need to go back into the Material Room and tweak the settings.
This will be my last render for the evening. Going to bed. Can pick this up at daybreak. Maybe I can find something for you.
anniemation ( ) posted Sun, 12 April 2020 at 11:44 PM
Thank you MissB!
hborre, this will be a freebie but if you come up with something I'll definitely give you credit. I like the metal in the render I posted as it has some texture to it. It does render that way in SF though.
anniemation ( ) posted Mon, 13 April 2020 at 4:51 AM
I think I got it! Thank you so much for the help hobrre!
hborre ( ) posted Mon, 13 April 2020 at 7:05 AM
Online Now!
Good. I'm glad to have been some help. That rendered very well. If you are looking for some great texturing tutorials, search for bagginsbill. Some of his stuff in the Material Room may look complicated but he tries to simplify the physics and math so you may understand the rationale behind realistic rendering.
Miss B ( ) posted Mon, 13 April 2020 at 2:33 PM
Ohhh, that rendered very well, and I agree with hborre about checking out BB's tutorials, as the man knows his stuff. I've never been disappointed in any of his goodies, or his tutorials on how to get something accomplished.
_______________
Butterfly Dezignz
