Tue, Feb 18, 12:32 AM CST
Forum Moderators: RedPhantom
Subject: Lamp shade material?
gmm2 ( ) posted Fri, 24 April 2020 at 2:09 PM ยท edited Tue, 18 February 2025 at 12:17 AM
I'm making a lamp prop that I intend to be as functional as possible. That is, it'll have a working switch to turn on or off a specific point light located where the bulb would be. As part of this, I'd like for the shade of the lamp to have a proper translucent material that reacts appropriately to that point light (and ideally, also to only an ambient material light). The problem is I can't figure out or find how to do that sort of translucency properly. Any tips?
ghostship2 ( ) posted Fri, 24 April 2020 at 4:40 PM
what I did with this is use a mix of SSS and diffuse with my free shader. Not sure if SSS would work with all lampshade models or if it would look any good with the light off lit externally. Also, the point light is set to inverse square and I have 6 diffuse bounces set in the render settings so the light gets around. You'll want walls for the light to bounce around on. It looks good that way but is a bit noisy. lampand chair.jpg
gmm2 ( ) posted Fri, 24 April 2020 at 6:31 PM
Thank you so much! That looks like exactly what I'm after.
gmm2 ( ) posted Fri, 24 April 2020 at 7:47 PM
Well, it's not working for me. I can get, at best, some light on the edges of whatever the light's behind, which is the exact opposite of how it should look.
structure ( ) posted Fri, 24 April 2020 at 10:51 PM
Forum Coordinator
Locked Out
bagginsbill ( ) posted Sat, 25 April 2020 at 11:29 AM
There's an extensive thread on translucent shaders in the old SM thread here https://forum.smithmicro.com/topic/1580/we-need-a-hair-shader-like-this-for-poser-shader-gurus/112
bagginsbill ( ) posted Sat, 25 April 2020 at 11:30 AM
I'm going to repost the findings in case that site is lost.
bagginsbill ( ) posted Sat, 25 April 2020 at 11:31 AM
bagginsbill ( ) posted Sat, 25 April 2020 at 11:33 AM
bagginsbill ( ) posted Sat, 25 April 2020 at 11:34 AM
bagginsbill ( ) posted Sat, 25 April 2020 at 11:35 AM
PAY ATTENTION - SCATTER ONLY WORKS WITH A VOLUME, NEVER WITH A SINGLE SIDED POLYGON.
bagginsbill ( ) posted Sat, 25 April 2020 at 11:36 AM
gmm2 ( ) posted Sat, 25 April 2020 at 12:37 PM
bagginsbill posted at 12:34PM Sat, 25 April 2020 - #4387326
Thank you so much for all this info! I tried this out and it's doing what I want, even with ambient lights. I'll have to mess around with it more to get it looking just how I want, but this is a big help.
Thanks to structure as well; I may try combining these two methods.
bagginsbill ( ) posted Sat, 25 April 2020 at 1:06 PM
Structure's setup seems to work exactly the same. But only for SuperFly.
bwldrd ( ) posted Sat, 25 April 2020 at 3:02 PM ยท edited Sat, 25 April 2020 at 3:03 PM
@bagginsbill
This may be a dumb question, but is that diffuse node attached to the translucence in your first post (with an image) actually doing anything? I thought those dashed lines meant that node wasn't working with the node it was plugged in with.
Consider me insane if you wish, but is your reality any better?
bagginsbill ( ) posted Sun, 26 April 2020 at 6:41 AM
The dashes DO mean that but only for SuperFly. For FireFly if you do not place a Diffuse at that position then the Translucence just glows no matter what.
As was already shown by Structure, if you're using the old Poser Surface root node but for SuperFly, you must NOT plug in a lighting node there. For FireFly you MUST plug in a lighting node precisely as I showed.
