Sat, Jan 18, 1:20 PM CST
DAZ|Studio F.A.Q (Last Updated: 2025 Jan 17 1:40 pm)
Subject: daz 3d newest version xxxx
goofygrape ( ) posted Thu, 28 May 2020 at 5:49 PM ยท edited Sat, 18 January 2025 at 7:19 AM
new computer, new win 10 installation, new studio install I have no add on files, just the factory setup. Most went into some sort of cloud? I put the 3rd party files into (Documents Daz 3D studio My library ) under c: users Public Public Documents My Daz 3D Library that is were Daz 3d put files, Not much but files mostly, I just understand this cloud thing ?, if this is my problem how to fix it? Thank's goofygrape aka John
RHaseltine ( ) posted Fri, 29 May 2020 at 9:23 AM
The /data/cloud/ folder in the Daz Connect Data directory has all the products you install through Daz Studio itself, one product per folder with the folder named for the SKU. All those sub-folders appear merged in the Daz Connect container in Daz Studio Formats/Poser Formats in the Content Library pane.
goofygrape ( ) posted Fri, 29 May 2020 at 2:21 PM
RHaseltine: How do I get it to read the files in the Documents folder, should I put them into the Daz studio formats folder?
RHaseltine ( ) posted Sat, 30 May 2020 at 3:09 PM
Which? /Daz 3D/Studio/My Library/ and the Connect library should already be set as content directories by default, as should the My Daz 3D Library folder in Public Documents. Or are you having trouble with the MS OneDrive system moving stuff out of the Documents folder.
goofygrape ( ) posted Tue, 02 June 2020 at 12:33 AM
YES, that is what has happened. I closed onedrive I think ?,I went to it and 1000's of files are there, Microsoft wants me to start a subscription Not going to happen. Daz 3d /studio/ my library/ is where everything is stored. ( users public/public documents/my Daz 3d library/ has only the basic studio files. I do not know were the Connect library is. On this new install, I noticed the onedrive thing but paid no attention to it, a bad mistake I guess. What to do now reinstall?
RHaseltine ( ) posted Tue, 02 June 2020 at 4:26 PM
Reinstalling won't change settings, what you need to do is make sure that the settings match the actual locations of the files. Make a list of which folders contain Runtime and/or data folders - those are probably your actual content directories (make sure you don't have one listed folder inside another) - the main exception being all the Connect folders, if anything was installed that way, where you want the folder that holds the /data/cloud/ folder not the /data/cloud/1_xxxxx/ folder that holds each product's own Data and Runtime folders.
Once you have the list you need to go to Edit>Preferences, then the Content tab within that, then click Content Directory Manager - there you can add, remove, and edit folders as needed.
goofygrape ( ) posted Wed, 03 June 2020 at 9:50 PM
Ok, I'll do this and let you know the outcome I've done some of this last night anyway, Thank's for your generous help.
goofygrape ( ) posted Thu, 04 June 2020 at 7:43 PM
This is what happened, Disk C: usersPublicPublic DocumentsMy Daz 3D Library, this is where everything is. reality 4.3 is where it is supposed to be, all extra folders in the studio desk to are gone. I found out that the installer was putting folders all over the place, because of that onedrive I stoped it and removed all of its files. Now studio works like it is supposed to.?? RHaseltine I surely Thank You for all the help John
RHaseltine ( ) posted Fri, 05 June 2020 at 2:17 PM
Great, I'm glad it is working now.
