You can reinstall Poser 11.2 or up, I believe.
The OP wants to install a pre-Bondware version. He can't, because the SM license server is no more. And if he had it already installed, it would no longer work, because Poser 11 phones home, and that number is now disconnected.
There should be no problem reinstalling 11.3.
some questions need to be asked. What OS? Where are your runtimes stored? My setup is on a PC with Poser 11.3 on the main drive (C) and the main factory runtime installed in the Poser folder where it always has been. I then have a second runtime called "OLD Runtime" on another HD. I keep all my purchased and made stuff on the old runtime.
I have Poser 11.3 on the C drive and main factory runtime on an external drive. Just because I like to keep a lot of free space on the C drive.
I have dozens of runtimes with old content, on an external drive. And I have to add them again, each time I update Poser. Even keeping your existing preferences doesn't keep your runtimes attached. At least it doesn't for me. Maybe this is the problem the OP is having?
"Poser 11.3 for anything except La Femme/ L Homme"
Structure: I tried to show Poser 11.3 where the runtime was at and it said it is not a recognized runtime
I can use La Femme and L homme but poser does not see the files in downloads. like they are not there if it does see any files, and it said it is not a recognized runtime. I would have to try and get Poser 11.3 to repeat the exact wording
thanks for the replies
When Poser doesn't recognize a runtime, it's usually because the folder structure is wrong.
In the Add Runtime action, Poser allows you to point at the Runtime itself, or point at the folder directly above Runtime. If you try to select a folder that's two levels above a Runtime, it won't work.
My python page
My ShareCG freebies
This happens a lot with Daz products, which place a 'content' layer between the main named folder and the Poser Runtime. If you point at the main name, Poser doesn't recognize the 'content' layer.
My python page
My ShareCG freebies
The current DAZ content files play havoc with Poser if you use 3rd party compression programs to install using default settings. Those files are meant to be installed with DIM, granted if you are familiar with the app, and understand how to navigate it. Otherwise, crack open the DAZ content file and examine its hierarchy before extracting.
What OS are you using? Where is the runtime (or runtimes) with M4 and V4 in it? Is this a runtime that worked well with Poser 11.0, or are you installing from scratch on a new computer? Can you post a screenshot of the file structure of the runtime Poser doesn't like?
There is no reason a runtime that worked with Poser 11.0 shouldn't work with 11.3.
when I tried to install again it refused my serial number. said I had reached the maximum uses . yes content paradise had it's demise with Renderosity's purchase of Poser 11.0. did Poser 11 have it's demise also?. at least Poser 11 recognized my runtimes, more than 11.3 does
