Thu, Feb 20, 12:16 AM CST
Forum Moderators: nerd Forum Coordinators: Anim8dtoon
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2025 Feb 18 8:01 am)
banner
Subject: Where is the color map node?
HartyBart ( ) posted Sun, 09 August 2020 at 9:09 AM · edited Tue, 18 February 2025 at 3:20 PM
A number of node-setup screenshots for Poser's Material Room show a "Color Map" node in use. Where is this seemingly vital node to be found in Poser? It appears to be missing from Poser 11's various node-choices drop-down menus. Was it taken out in Poser 11? If so, what is the most suitable substitute?
infinity10 ( ) posted Sun, 09 August 2020 at 9:40 AM · edited Sun, 09 August 2020 at 9:40 AM
Nodes can be renamed by clicking on the node name so let's assume that's what the creator did. For Poser Root Surface, I assume it would be the Math:Simple_Color node. For the Cycles Root Surface nodes, I take it to be the Cycles:Input:Color node. Needs a bit of right-clicking in the Material Room window.
Eternal Hobbyist
Rhia474 ( ) posted Sun, 09 August 2020 at 9:41 AM
Not sure what you mean--are you referring to color texture maps aka diffuse maps as they were known in Firefly? . Direct quoted from the manual:
Color texture maps are commonly known as diffuse or diffuse color
maps in non-PBR renderers such as Firefly. In PBR-type renderers
such as SuperFly they are more commonly known as Albedo maps. The
main difference between a diffuse texture and an albedo texture is
that albedo textures contain no baked-in highlights or shadows.
In the PoserSurface node, color maps typically connect to either
the Diffuse_Color or Alternate_Diffuse channel, either directly or
through other material nodes. In the Physical Surface root node, the
Diffuse/Albedo map connects to the Color input.
Rhia474 ( ) posted Sun, 09 August 2020 at 9:42 AM · edited Sun, 09 August 2020 at 9:42 AM
And yes, all you need to do is doubleclick on the name of the node and you can rename. I dislike this because it confuses end users a lot.
donnena ( ) posted Sun, 09 August 2020 at 10:24 AM · edited Fri, 11 September 2020 at 11:57 AM
You are not alone in disliking node name changes
Please see a cure for this here!
Reveal Node Type
Andy!
Rhia474 ( ) posted Sun, 09 August 2020 at 11:14 AM
YAY! Thank you!!
donnena ( ) posted Sun, 09 August 2020 at 11:33 AM
Thank structure ! He did all the heavy lifting. I just remembered where he left it!
Andy!
EldritchCellar ( ) posted Sun, 09 August 2020 at 11:41 AM
I second that. The script works great.
Thanks Structure
HartyBart ( ) posted Mon, 10 August 2020 at 6:53 AM · edited Mon, 10 August 2020 at 6:57 AM
I'd forgotten about the "Reveal node name" Python script, thanks. Though that doesn't work with old screenshots.
Turns out that "Colour map" is a re-named node commonly used by BagginsBill and a few others node-gods. Underneath it's actually just the good old Image_Map node, with only the image made visible.
