Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2025 Jan 26 5:56 am)
Nodes can be renamed by clicking on the node name so let's assume that's what the creator did. For Poser Root Surface, I assume it would be the Math:Simple_Color node. For the Cycles Root Surface nodes, I take it to be the Cycles:Input:Color node. Needs a bit of right-clicking in the Material Room window.
Eternal Hobbyist
Not sure what you mean--are you referring to color texture maps aka diffuse maps as they were known in Firefly? . Direct quoted from the manual:
Color texture maps are commonly known as diffuse or diffuse color
maps in non-PBR renderers such as Firefly. In PBR-type renderers
such as SuperFly they are more commonly known as Albedo maps. The
main difference between a diffuse texture and an albedo texture is
that albedo textures contain no baked-in highlights or shadows.
In the PoserSurface node, color maps typically connect to either
the Diffuse_Color or Alternate_Diffuse channel, either directly or
through other material nodes. In the Physical Surface root node, the
Diffuse/Albedo map connects to the Color input.
You are not alone in disliking node name changes
Please see a cure for this here!
Reveal Node Type
Andy!
I second that. The script works great.
Thanks Structure
I'd forgotten about the "Reveal node name" Python script, thanks. Though that doesn't work with old screenshots.
Turns out that "Colour map" is a re-named node commonly used by BagginsBill and a few others node-gods. Underneath it's actually just the good old Image_Map node, with only the image made visible.
A number of node-setup screenshots for Poser's Material Room show a "Color Map" node in use. Where is this seemingly vital node to be found in Poser? It appears to be missing from Poser 11's various node-choices drop-down menus. Was it taken out in Poser 11? If so, what is the most suitable substitute?
