Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 7:34 am)
If you can tolerate concentric, there's a record in my Broadcasting set with a fairly fine set of concentric circles plus spiral leadin and leadout. It's a bump map.
https://sharecg.com/v/88375/gallery/11/Poser/KDV-a-1930s-radio-station
You have permission to use the record or the map.
My python page
My ShareCG freebies
Thanks, all.
I really haven't considered modelling the detail in. Oh, not ever. I'm not daft, yer know. I've always wanted it to be a texture file and so far, I've been using a high res PNG, which is OK but I'd love something a bit more... spiraly.
@ockham: Many thanks. I'll take a look at it and may borrow some of it for my own use. If I ever release anything (doubtful, at least in the immediate future) I'll make sure you get the credit.
Don't worry, I owe you some 'value' after using your Daleks often!
My python page
My ShareCG freebies
Well, that's a bit of an embuggerance. :(
It's the same as this for Firefly. I didn't faff with the spec or bump settings or even render it to see but it's essentially the same mat...
Oh yes. The bump value in my screen shot is absurdly high. Funny because my go to default value for bump testing is 0.02 as you show (inches)
Also yes. Anisotropic is a very strong specular, probably why so many in the past have used it for specular on transparent materials like cornea and such.
Anyway...
Ideally for both 7" (Single) and 12" (LP) types.
I thought about scanning the damn things but that gives somewhat unsatisfactory results, even with the cleanest scanner glass and a near as dammit pristine record. Different colour vinyl doesn't seem to help, either.
The best I came up with so far is a series of thin, narrowly spaced concentric circles but the detail geek in me ain't satisfied with this.
Even a rudimentary spiral is a major pain in the rear end, it seems, so if anyone found a way to do it without causing endless pain, suffering, outbreaks of bad language and whatnot will have my gratitude.
