Sun, Jan 5, 4:33 AM CST
Subject: Does anyone know how to make a spiral track, as on a vinyl record?
SamTherapy ( ) posted Thu, 10 September 2020 at 10:40 AM · edited Sun, 05 January 2025 at 4:30 AM
Ideally for both 7" (Single) and 12" (LP) types.
I thought about scanning the damn things but that gives somewhat unsatisfactory results, even with the cleanest scanner glass and a near as dammit pristine record. Different colour vinyl doesn't seem to help, either.
The best I came up with so far is a series of thin, narrowly spaced concentric circles but the detail geek in me ain't satisfied with this.
Even a rudimentary spiral is a major pain in the rear end, it seems, so if anyone found a way to do it without causing endless pain, suffering, outbreaks of bad language and whatnot will have my gratitude.
hborre ( ) posted Thu, 10 September 2020 at 11:20 AM
I assume that you will be creating a bump mappings for the vinyl discs? Considering how many circles it will take to create a decent disc, you may need to consider an image. If you have photoshop or GIMP, there may be a template available you can work with.
ghostship2 ( ) posted Thu, 10 September 2020 at 11:21 AM
how about using a high rez tiff file for bump instead of modeling in all that detail?
NikKelly ( ) posted Thu, 10 September 2020 at 11:40 AM
Have you considered applying a free hi-res image to a plain disk ?? Use grey-scaled image as a bump/displacement map ??
I reckon many CAD packages could craft a disk with actual groove, per 'turning thread on a bolt', but result would be very, very high-poly, akin to a complex terrain model...
rokket ( ) posted Thu, 10 September 2020 at 12:16 PM
How close do you intend to get to the vinyl to render? You may get away with a spec map that suggests the grooves instead of trying to create a bump map.
ockham ( ) posted Thu, 10 September 2020 at 12:47 PM
If you can tolerate concentric, there's a record in my Broadcasting set with a fairly fine set of concentric circles plus spiral leadin and leadout. It's a bump map.
https://sharecg.com/v/88375/gallery/11/Poser/KDV-a-1930s-radio-station
You have permission to use the record or the map.
My python page
My ShareCG freebies
SamTherapy ( ) posted Thu, 10 September 2020 at 12:52 PM
Thanks, all.
I really haven't considered modelling the detail in. Oh, not ever. I'm not daft, yer know. I've always wanted it to be a texture file and so far, I've been using a high res PNG, which is OK but I'd love something a bit more... spiraly.
@ockham: Many thanks. I'll take a look at it and may borrow some of it for my own use. If I ever release anything (doubtful, at least in the immediate future) I'll make sure you get the credit.
ockham ( ) posted Thu, 10 September 2020 at 1:43 PM
Don't worry, I owe you some 'value' after using your Daleks often!
My python page
My ShareCG freebies
adp001 ( ) posted Thu, 10 September 2020 at 10:46 PM
SamTherapy ( ) posted Fri, 11 September 2020 at 1:00 AM
adp001 posted at 7:00AM Fri, 11 September 2020 - #4399176
Would that work in Firefly? I don't use Superfly.
rokket ( ) posted Fri, 11 September 2020 at 10:20 AM
It won't work in Firefly, Sam. It's a cycles material.
SamTherapy ( ) posted Fri, 11 September 2020 at 11:02 AM
Well, that's a bit of an embuggerance. :(
EldritchCellar ( ) posted Fri, 11 September 2020 at 11:14 AM
It's the same as this for Firefly. I didn't faff with the spec or bump settings or even render it to see but it's essentially the same mat...
SamTherapy ( ) posted Fri, 11 September 2020 at 1:26 PM
Cheers, mate! I'll give it a go.
adp001 ( ) posted Fri, 11 September 2020 at 2:08 PM
It works. But different.
This may be a start to experiment. And set the bump intensity mutch lower. For me it is 0.02.
Anisotropic depends hardly on light. And needs high render values.
EldritchCellar ( ) posted Fri, 11 September 2020 at 2:42 PM
Oh yes. The bump value in my screen shot is absurdly high. Funny because my go to default value for bump testing is 0.02 as you show (inches)
Also yes. Anisotropic is a very strong specular, probably why so many in the past have used it for specular on transparent materials like cornea and such.
Anyway...
adp001 ( ) posted Sat, 12 September 2020 at 3:03 AM
About anisotropic lighting in renders:
https://www.opengl.org/archives/resources/code/samples/sig99/advanced99/notes/node154.html
EClark1894 ( ) posted Sat, 12 September 2020 at 12:41 PM
It's something I have in the works, but I expected to have to get into before long. I planned to go with either a normal map or bump myself.
