Wed, Nov 20, 10:33 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 20 6:12 am)
Subject: Remove eyeliner on La Femme?
CassandraNorth ( ) posted Fri, 11 September 2020 at 2:13 AM ยท edited Wed, 20 November 2024 at 10:17 AM
Is there a way to remove La Femme's eyeliner? Currently, I am using either the default skin or Fabiana's. Nothing wrong with either skins, but for this specific render it would work better with no eyeliner.
randym77 ( ) posted Fri, 11 September 2020 at 7:00 AM ยท edited Fri, 11 September 2020 at 7:10 AM
Some vendors provide a "no makeup" option (though admittedly, a lot of vendors don't seem to know what women without makeup actually look like).
I think La Femme's default skin comes in with no eyeliner. If not, there's a "Face Natural" option for her in the materials section of the library.
She does have very long, dark eyelashes. Maybe toning those down would give you the look you want? Make them paler, or even turn them off.
CassandraNorth ( ) posted Fri, 11 September 2020 at 7:06 AM
I do want the makeup but not the eyeliner as it is too heavy for the image in mind.
Maybe I should just find another skin to use ?
randym77 ( ) posted Fri, 11 September 2020 at 7:18 AM
That's pretty much your only option unless you're willing to edit the maps yourself in Photoshop or whatever.
Are none of the options for the default LaFemme suitable? There's a variety, from no eyeliner to some eyeliner to heavy cateyes.
Rhia474 ( ) posted Fri, 11 September 2020 at 8:13 AM
Online Now!
If you are working with vendor made textures, what you see is what you get. You can look for a texture pack for LaFemne that has makeup on eyes but no eyeliner, or see if you can use GIMP or Photoshop to doctor what you already have but be aware of the copyright limitations in that case.
hborre ( ) posted Fri, 11 September 2020 at 8:14 AM
As randym77 posted, I afraid it is either finding a different skin texture or, if you're skilled enough, editing the texture map in Photoshop or GIMP.
CassandraNorth ( ) posted Fri, 11 September 2020 at 8:18 AM
Thank you, all ? now I have a couple of ideas!
EldritchCellar ( ) posted Fri, 11 September 2020 at 9:18 AM ยท edited Fri, 11 September 2020 at 9:23 AM
As hborre said (except for the "if you're skilled enough" part, the only skill this requires is having an image editor), Import your no makeup texture as a background layer in your image editor. Import your makeup texture as a layer above. Use the eraser to erase the eye makeup part from the makeup texture, revealing the no makeup texture below. Flatten image. Save as a new file...
EldritchCellar ( ) posted Fri, 11 September 2020 at 9:32 AM
The textures included with LF are considered vendor resources. That is, any derivative edits you create from the included files can be used in a supporting commercial product.
EldritchCellar ( ) posted Fri, 11 September 2020 at 9:38 AM
If you're looking for a decent skin MR for La Femme I'd recommend this...
https://www.renderosity.com/mod/bcs/gail---la-femme-precious-merchant-resource/135938
It's one of the better ones; lots of options, a good base with only a few very minor seams and visible clone stamp areas... all easily fixed. Also easy to remove the minor baked in specular and shadow.
CassandraNorth ( ) posted Fri, 11 September 2020 at 12:54 PM
Thank you, EldritchCellar! Sadly the skin you recommend is no longer available.
Editing it is ?
EldritchCellar ( ) posted Fri, 11 September 2020 at 1:17 PM
CNorth posted at 2:15PM Fri, 11 September 2020 - #4399256
Editing it is ?
Humph. That's weird. Wonder why they pulled it? Glad I got it when I did. Sorry for the misdirection...
CassandraNorth ( ) posted Fri, 11 September 2020 at 2:14 PM
No problem ? sadly it was what I was looking for but maybe someone will release something similar at one point
Boni ( ) posted Sat, 12 September 2020 at 8:43 AM
May I suggest contacting the vendor on whether this is being re-packaged for a future release?
Boni
CassandraNorth ( ) posted Sat, 12 September 2020 at 9:06 AM
Brilliant idea, Boni! Will do!
