Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 04 3:06 am)
Submit a request to bondware.?
Where is the official poser SDK/API Documentation? that any legitimate programmer would Demand to Port over an open source render engine??
Also what is being offered in terms of financial compensation for his/her work?? ?
Looks like rendering with hyper boosted sketch presets.
Intel Core i7 920, 24GB RAM, GeForce GTX 1050 4GB video, 6TB HDD
space
You can more or less do this already with Poser renders, and the result has less of a 'made by machine' look. You just need to accept that it's not all going to be done in one-click. At least three renders are needed, though these can all be real-time. First output real-time lineart, then real-time color flats, then a real-time shadows render. Take these to Photoshop, filter the flats (two times if needed), blend in the line-art on top, subtly ease in the shadows render. Here is a simple three-render blend, with the flats filtered twice in Photoshop:
There are also the possibilities of adding things like a Sketch render that was run into the lineart only, to give you more 'hand-drawn' lines. And if you want to get really fancy, you can do things like re-texture in the scene with the free PASS watercolor art shaders (now available again from the maker, who is now on the ArtStation market).
I have a hard time getting the exact results I want within Poser. I usually end up using Photoshop, often with transparent layers to get the mix of realistic and hand-drawn that I want. And what formula works best depends a lot on what kind of image it is. What appeals to me about the linked project is it's supposed to be adjustable.
I don't have the coding skills but, would any kind soul with the interest and aptitude consider using the opensource item and porting a version across to Poser ? It allows for expressive non-photorealistic rendering:
https://artineering.io/publications/MNPR/
Eternal Hobbyist
