Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2025 Jan 08 11:18 am)
Yes, know about the Copy Morphs From. Sadly they don't always react the way I need them too since the geometry is different from L'Hommes but the smoothing brush works a trick to fix stuff like that.
It's sad that a morph can't be moved. Seems odd to me.
---Wolff On The Prowl---
I have not tried this, but it might work. zero out every other l'homme morph but the one you want. Select the head. Then use the spawn morph target under the object menu. You can then delete the original body morph, or at least zero it out.
You cannot move a morph because you do not have to. The morph is already there. You just do not see its dial because it is hidden. Make it visible and you have what you want. You can then delete the dial in the body actor. The only thing the dial in the body actor does is take and hold your input.The parameter (dial) in the head actor 'knows' it has to get the value from its 'master' parameter in the body actor and add it to its own value setting before working its effect (= move vertices around)
'Answer:
If all you want is to display the morph on the parameters menu in the HEAD portion of the parameters menu it's easy to do so.
Open the Body morphs on the parameter menu (with the + symbol) and do the same on the Head morph list.
Then, using your mouse left button, click on and HOLD the button from the Body list and drag it to the Head list. The NAME of the morph is where you need to GRAB the morph with the mouse.
Don't let go of the left mouse button until you have the morph where you want it. You'll see a line following the mouse movement as you drag it around. We Poser users always seem to make things harder than they have to be'
As told to me by Glitterati3D
Is there a way to move a morph from the root (body) to the head? This is for a face prop I've made but the morph really needs to be in the head area, not the body and I have NO IDEA how to move a morph in Poser. Easy in DS but so far no luck figuring that out in Poser.
Thanks so much Richard
My Store is HERE
My Freebies are HERE
