Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2025 Jan 08 11:18 am)
at first glance, I'd say that the front and back of the head are 2 different material zones and the shaders don't match. My second guess would be that the skin on the image map doesn't match. There also look like there is a similar seam on the back of the head.
Skin looks fine with other shader set ups. The skins all match. This is L'Homme, the line you see is where the Head and the Torso maps meet!
---Wolff On The Prowl---
Well I thought that too but I have copied and replaced the nodes for the Face, Torso and Limbs with the same and then just browsed and changed out all the image nodes with the appropriate maps! Double checked to make sure I didn't mess up anywhere but they are all done correctly!
Are you sure that isn't a reflection of your skydome being shown across the head? It sure looks like it to me. I'd suggest changing/removing the Alternate_Specular and see if it still shows up.
Consider me insane if you wish, but is your reality any better?
Yes, tried that as well, unplugged most stuff one by one and the issue remains so next is to try the lighting and see if that's the culprit.
Well strangely enough it's the maps themselves so not sure why I didn't notice this before. I'm in 3D Coat now fixing them. Thanks for the help!
See the image below. Node settings there to look over
Thanks so much
Richard
My Store is HERE
My Freebies are HERE
