Thu, Jan 30, 10:05 PM CST
Renderosity Forums / Poser 12
Welcome to the Poser 12 Forum
Poser 12 F.A.Q (Last Updated: 2025 Jan 26 3:18 pm)
Subject: Stonemason UrbanFuture2 in Poser12
722 ( ) posted Fri, 11 December 2020 at 4:10 PM · edited Thu, 30 January 2025 at 10:05 PM
loud up UrbanFuture2 in P12 takes long time change the illumines in the signs, then I render poser disappears poof anyone els have this problem with UrbanFuture2 in P12
hborre ( ) posted Fri, 11 December 2020 at 4:21 PM
Sounds like some of the objects are poly heavy and high-resolution textures. Have you checked the Material Room for proper node connections? This is set is not P12 tested. I do own it but it is not currently in my runtime ATM.
seachnasaigh ( ) posted Fri, 11 December 2020 at 4:30 PM · edited Fri, 11 December 2020 at 4:34 PM
With the introduction of Superfly, I reworked the materials for Urban Future, Urban Future 2, Urban Future 3, and other Stonemason sets, and made the materials Superfly-friendly and made the signs and lights mesh lights. There are a lot of invalid material node connections in the original materials (OK for Firefly, invalid for Superfly). That might account for delayed loading; P12 shouldn't crash because of it, however. I'll try rendering it in P12 when I get back; I'm going to escort some of the neighborhood teens on a bike ride (parents like to have at least one armed adult with the young'uns).
seachnasaigh ( ) posted Fri, 11 December 2020 at 5:24 PM
I loaded my Superfly version of Urban Future 2 in P12; when I tried to render (Superfly), Poser crashed.
Hmmm, no minidump, no WER. I copied the info from the crash notice popup. I'll need to do some experimenting.
ghostship2 ( ) posted Fri, 11 December 2020 at 10:37 PM
if you got any ambient occlusion nodes plugged in anywhere the render will crash. AO is not supported and not needed with PBR. Might be other nodes doing the nasty but since you'll likely have hundreds of mat zones to check you'll have your work cut out for you finding the issue.
ChromeStar ( ) posted Sat, 12 December 2020 at 12:25 AM
AO nodes haven't been crashing for me in superfly, it just results in an all-black render. Your mileage may vary. Still need to remove those nodes though. It would be better if Poser just knew to ignore them. But anyway, I don't know that the symptom matches here.
seachnasaigh ( ) posted Sun, 13 December 2020 at 5:30 PM
@ghostship2 ; I eliminated every AO node (there were a lot) when I modified it for the first Superfly release, so it wasn't that. This time I deleted a lot of reflect nodes and even a few gather nodes (circa P5!), and used more dual root material setups to use the PhysicalSurface root for metals.
I'll need to make some simpler model to test which node/nodes is causing the crash.
But here is a P12 Superfly render of Urban Future 2:
There are umpteen subsidiary props in this set, and many have a dozen or more material zones, so forget about a MAT file. However, I did save the modified prop set out as a PP2, and after removing Stonemason's OBJs and JPGs, zipped it up as a PP2. Assuming one has Urban Future 2, they will be able to open and use my re-textured version. I'll get that posted to freebies.
JimTS ( ) posted Sun, 13 December 2020 at 10:57 PM
sounds like a job job for easyskin
A word is not the same with one writer as with another. One tears it from his guts. The other pulls it out of his overcoat pocket
Charles Péguy
 Heat and animosity, contest and conflict, may sharpen the wits, although they rarely do;they never strengthen the understanding, clear the perspicacity, guide the judgment, or improve the heart
Walter Savage Landor
So is that TTFN or TANSTAAFL?
722 ( ) posted Mon, 14 December 2020 at 11:46 PM
seachnasaigh posted at 11:45PM Mon, 14 December 2020 - #4407416
Ya!! thanks so much
seachnasaigh ( ) posted Thu, 17 December 2020 at 8:37 AM · edited Thu, 17 December 2020 at 8:44 AM
I made some corrections; the updated version is has "mod 4" in the name.
Test renders:
overall view: Urban Future 2 - mod 4 pano.jpg
I "turned on the lights" in some of the windows... Urban Future 2 - mod 4 - sample 1.jpg
Link to the freebie:
P12 Superfly lightcaster for Urban Future 2 (mod 4)
seachnasaigh ( ) posted Thu, 24 December 2020 at 2:01 PM
I've made some corrections to this package, and added some pieces (interior room, hallways, meshlight ceiling light fixtures). The new zip is "mod5e".
Urban Future 2 P12 Superfly meshlight modification 5e
