Wed, Nov 20, 9:27 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 20 6:12 am)
Subject: Using Poser, but HOW do I install stuff from Daz?
Royfitz ( ) posted Tue, 29 December 2020 at 1:24 PM · edited Wed, 20 November 2024 at 9:24 AM
I've tried install manager, Daz central - nothing works. The programs won't even open despite umpteen install-remove-install. I can't download the new content I've just bought!
Manual download gives me 3 zip files, but I have no idea what to do with them...
HELP!
hborre ( ) posted Tue, 29 December 2020 at 1:43 PM
Online Now!
DAZ Install Manager works perfectly fine. You need to specify where the content is to be installed, but you also need to create the pathway to your content folder. To begin, what type of content did you purchase from DAZ? Does it include both Poser and DAZ installation zips? Provide as much information as you can.
Royfitz ( ) posted Tue, 29 December 2020 at 1:53 PM
I bought Victoria 4.2 from Daz. It does say it works in Poser. The Daz install manager will not work. It's won't open, however many times I install/uninstall it. Neither will Daz central.
I now have 3 zip files - one is called 'base figure' so I'm guessing that's the one I really need. I don't mind don't it manually, but I'm not sure how.
hborre ( ) posted Tue, 29 December 2020 at 2:20 PM
Online Now!
As I stated previously DIM does work, it's just being used incorrectly. The only zip file you require for Poser is the Poser Core Installer. If you open the file with Winzip, Winrar, etc. you will find a primary folder called content. When you enter this folder, the secondary folder should be Runtime. There might be other folders along with it but that's okay, they should be at the same level as Runtime. It is this folder and any other folders along with it that get unzipped into your content folder.
Now, how is Poser set up on your computer and where is your content being installed? We're talking about a rather old program here, so I hope we can get you going on the right track.
Royfitz ( ) posted Tue, 29 December 2020 at 2:33 PM
DIM may work fine for some. Not for me. It's not a case of being used incorrectly. The program will not open or run. I have the desktop icon but nothing I do opens the prog. Extremely frustrating. Yes, I have an old system and old Poser but for me, 'if it ain't broke, don't fix it'...
I just wish I could get V4 to install.
hborre ( ) posted Tue, 29 December 2020 at 2:40 PM
Online Now!
And we can if you have a decompression program, Winzip, Winrar, or 7-zip will do. What type of system are we talking about and where is P5 installed?
Royfitz ( ) posted Tue, 29 December 2020 at 2:46 PM
P5 is on my hard drive. I have unpacked the installer and lo and behold - it just worked for the first time. However, I used it it to install V5 but she still does not show. If I go in to my characters via file manager, there is a folder full of sub-folders within the Daz characters area. They do not do anything. I think I need to swallow a £23 purchase and just delete it.
randym77 ( ) posted Tue, 29 December 2020 at 2:47 PM
Use the zip files. I find them a lot easier, and you can put the items where you want them. The one for the V4 base is called IM00004783-01_Victoria42Base.zip. (The other two files that come with it are for DAZ Studio. It might seem complicated, but you'll soon recognize which files are for Poser and which are for DS.)
If you're using Windows, you can click on the zip file. There will be a folder called Content. Click on that, and find the folder called Runtime. Copy that to your runtime.
If you have WinZip or a similar program, you can just extract the Runtime folder to the folder containing your runtime.
randym77 ( ) posted Tue, 29 December 2020 at 2:50 PM
If you really bought Victoria 5...she won't work in Poser 5. You need Victoria 4.2.
Don't give up. Victoria 4 works in Poser 5, I promise.
DAZ has a money back guarantee, so if you bought the wrong version of Victoria, you can ask for a refund.
Royfitz ( ) posted Tue, 29 December 2020 at 2:53 PM
Apologies - a typo. I've got V4.2...
Royfitz ( ) posted Tue, 29 December 2020 at 3:00 PM
Randym77 - many thanks.
Idid as you suggested but there's no Runtime folder in there. The first inner folder is content, then people, then Victoria 4. When I go into Victoria 4, I get 2 more folders. Materials and Poses. Materials contains V4 samples. Poses contains a folder called general which has a whole load of DSB files.
There's nothing else...
randym77 ( ) posted Tue, 29 December 2020 at 3:01 PM
If you're still having trouble, post a screen shot of the DAZ folders you mention. They may have landed in the wrong place or something.
Did you get the V4 morphs, too, or just the base?
randym77 ( ) posted Tue, 29 December 2020 at 3:04 PM
Royfitz posted at 3:03PM Tue, 29 December 2020 - #4408893
That sounds like the DAZ Studio files. You don't need them for Poser. I think you unzipped the wrong file.
Royfitz ( ) posted Tue, 29 December 2020 at 3:13 PM
I've re-downloaded the whole thing and now I also have a file containing Runtime. I copied that folder into my Poser Runtime but still no V4. When I look in my explorer this I what I get...vic 1.jpg
hborre ( ) posted Tue, 29 December 2020 at 3:33 PM
Online Now!
Do not copy the V4 runtime into the Poser runtime, copy the V4 runtime into the Poser folder. The V4 runtime should merge with the Poser runtime. The way you are describing the install, you are nesting a runtime folder into a runtime folder. That will never work.
randym77 ( ) posted Tue, 29 December 2020 at 3:34 PM
Thanks, that helps a lot. You have the files, but they're not in the right places.
What version of Windows are you using? It looks like the file structure of the zip file was not preserved when you extracted it. Newer versions of Windows will keep the directory structure when you extract a zipped file, but if you're using an old version, or are using unzipper without "preserve structure" checked, it won't.
Royfitz ( ) posted Tue, 29 December 2020 at 3:38 PM
I'm using Windows 7... Yes, ancient but it works... I'll try hborre's idea...
randym77 ( ) posted Tue, 29 December 2020 at 3:38 PM
hborre posted at 3:37PM Tue, 29 December 2020 - #4408897
If that's what happened, it's an easy fix. Just copy the nested runtime into the main runtime. But that looks like the contents of the !DAZ folder in DAZ People.
Royfitz ( ) posted Tue, 29 December 2020 at 3:42 PM
OMG - MANY thanks hborre - IT WORKED!!!
Yes, she takes an AGE to load, with numerous error messages first, but SHE WORKS!!!
MANY thanks all you guys here. I'd be stuffed without your help.
randym77 ( ) posted Tue, 29 December 2020 at 3:51 PM
It might help to delete that Victoria 4 folder from inside DAZ People. (The folder, not the Victoria 4 files. Only Victoria 4.2.cr2 and Victoria4.2.png should be there. And the other DAZ figures you have, of course.)
Having two copies of those morph files (that's what they are) can cause problems.
Royfitz ( ) posted Tue, 29 December 2020 at 3:55 PM
Now that I have the figure, I'm somewhat surprised to find there are NO morph files - they cost an extra £25...!!! OUCH, DAZ...!!!
randym77 ( ) posted Tue, 29 December 2020 at 4:00 PM
You didn't get the Starter Bundle? The sale price was about $20 U.S. last weekend, and includes morphs, skin textures, hair, and clothing.
The base figure does include expression morphs, which weren't included with earlier versions of Victoria, IIRC.
Royfitz ( ) posted Tue, 29 December 2020 at 4:07 PM
OMG - Ripped off, or what...? No, I just got the base figure for $28...(£23)...
randym77 ( ) posted Tue, 29 December 2020 at 4:10 PM
That's the normal price. I never buy full price at DAZ. If you wait, it will always go on sale.
