Fri, Jan 24, 5:14 AM CST
Renderosity Forums / Poser 12
Welcome to the Poser 12 Forum
Poser 12 F.A.Q (Last Updated: 2025 Jan 20 8:00 pm)
Subject: Masks not required anymore ...
FVerbaas ( ) posted Wed, 03 February 2021 at 1:27 PM · edited Fri, 24 January 2025 at 12:42 AM
Forum Coordinator
The latest opdate of Poser 12 features the fix for a real pain: to dissect your .png to get a separate mask file.
The Cycles ImageTexture node now outputs the transparency (alpha) channel correctly. So, you need no mask anymore to crowd your scene with 'poster' figures.
The below image is simply an old Roxie .png I had, as cycles image texture on two squares. Note it correctly casts shadows. I did not make the squares 'look' at the camera, so I could show the principle.
The dead-simple shader I used for the PhysicalSurface node on the left square.
PoserSurface a little more complicated, on square on the right:
No separate masks needed anymore when you dare to go into the cycles nodes lists. Hurray!
Y-Phil ( ) posted Wed, 03 February 2021 at 3:31 PM
Cool! :-)
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
Kalypso ( ) posted Thu, 04 February 2021 at 9:38 AM
Site Admin
This is a pleasant change!
NikKelly ( ) posted Sun, 07 February 2021 at 9:09 AM
That's so neat.
D'uh, I usually dissect PNGs with IrfanView to their RGB and Alpha, save as JPGs...
AcePyx ( ) posted Sat, 13 February 2021 at 8:07 PM
That's helpful. Guess, pngs it is then.
