Poser 12 F.A.Q (Last Updated: 2025 Jan 19 10:19 am)
I had that problem. I can sign into Rendo with my email address or my username, but the Purchases tab only takes my username. Are you using your email address on the Purchases tab?
Old lady hobbyist.
All visual art or fiction is "playing with dolls."
I tried several times, on two workstations, so I don't think it's misspelled. Caps Lock is off. I used my Rendo username & password; I also tried email & password. I also whitelisted R'osity in Kamo.
Am I correct that I am supposed to use my R'osity username and password?
OSes: Win7Prox64, Win7Ultx64
I see you're using Windows 7. I wonder if that's the problem. Poser is supposed to be Win 10 and up. I know it works on 7, but maybe there's an issue with this part of it. Do you have a computer with win 10 you can try? Otherwise, you might need to talk to support.
RedPhantom posted at 3:07AM Mon, 26 April 2021 - #4417673
Yes, I know it's Win10+, that's why I pointed out that I'm on Win7. But, I tried the "included" radio button, and I can download and install with that. So, the point of failure is the login of the Renderosity radio button. It may indeed be a Win7 issue. I don't have a Win10 machine; I'm saving up and planning a Win10 workstation (hopefully with RTX 30XX GPUs), but until then all my machines are Win7.
This may sound stupid, but how do I contact support?
I recently purchased some content at R'osity's marketplace. For the Python utilities, I've installed manually, and I've used the P12 "install from zip archive" method.
Now I was going to try the embedded store. In the library window, I changed from the library tab to the purchases tab. This login UI appears.
I fill in the username and password which I use at the Renderosity marketplace. It responds with Unable to login with username/password.
What am I doing wrong?
Note: My workstations are Win7.
